The metal is probably from the front bearing. The squeeling is the clutch trying to engage a locked up compressor. Time to replace it.
Agree that the entire compressor needs replaced. I had good luck with a used unit from Ed Morad. About a quarter of the price of a rebuilt one and has lasted me almost 2 years.
If the noise is coming from the clutch along with the metal shavings, once the clutch wears out the noise should stop and everything should be fine except for a dead compressor... right or wrong?
I also checked to see if the compressor was loose, a sign of a bad bearing, and it is pretty tight little to no movement...
my dads buick had the same noise awhile back and i looked at it and there are metal shavings on that compressor too and the compressor still works...
