Thread: brake pedal goes to the floor
Results 1 to 13 of 13
  1. #1 brake pedal goes to the floor
    SE Level Member donalda's Avatar
    Dec 2010
    MD
    On my way to work this morning my brake pedal went to the floor. Almost hit somebody. With out taking it apart would anybody know what to look for? I just put new rotors and brakes on it a month ago. All was good this morning. Not sure what happened. Please give me your advise. Thanks in advance.
  2. #2 Re: brake pedal goes to the floor
    sounds like a broken line or you blew the cap off the reservoir.
  3. #3 Re: brake pedal goes to the floor
    Start the car and with it in park...pump the ever loving crap outta the brakes.. look underneath for a puddle.
    If it's intermittant and there is no puddle. The master cylinder is likely the problem.
  4. #4 Re: brake pedal goes to the floor
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    happend samething to me, I changed the master cylinder and everything was good!
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  5. #5 Re: brake pedal goes to the floor
    This happened to me and i blew a line under the rear driver door where the brake and gas lines run. It's rust city right there.
  6. #6 Re: brake pedal goes to the floor
    Dec 2010
    MD
    The line under the car is broken. Just about underneath the driver seat. So looks like a good time to just put a new one in. Here we go.
  7. #7 Re: brake pedal goes to the floor
    Feb 2009
    flintnasty MI
    Plan on doing both the rear lines... I spliced in just after they make the bend at the master cyl, and ran new lines from there to the calipers.
  8. #8 Re: brake pedal goes to the floor
    GT Level Member GMCustomerService's Avatar
    Michigan
    @donalda, I hope that everything goes smoothly with your repair.
    Michelle, GM Customer Service
  9. #9 Re: brake pedal goes to the floor
    Dec 2010
    MD
    thanks for the feedback guys. I do plan on replacing the whole line. Never done this job before, but i have the knowledge on how. I will post when I get finished.
  10. #10 Re: brake pedal goes to the floor
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    i replaced both lines all the way back. make sure you get a quality flare tool. it will save you a big headach.
  11. #11 Re: brake pedal goes to the floor
    Dec 2010
    MD
    found the leak. lines are rusty. I want to replace both. should I splice into them under the car or run all new from under the hood? But I am going to invest in a flair tool. Might have to do this job on my 96 Camero convertable.
  12. #12 Re: brake pedal goes to the floor
    Jul 2011
    Michigan
    i would go all the way back. from master to the caliper, all one line. thats the way i did it.
  13. #13 Re: brake pedal goes to the floor
    Jul 2011
    Michigan
    and definitly replace both. and inspect the front lines also.
  1. Brake pedal sometimes going to the floor while stopped
    By stotzbotz in forum General Tech Discussion
    Last Post: 10-05-2010, 07:29 PM
  2. Out of ideas, pedal to the floor
    By donkason in forum Brakes/Suspension/Chassis
    Last Post: 09-19-2010, 10:52 AM
  3. brake pedal very soft
    By Jenco in forum Brakes/Suspension/Chassis
    Last Post: 09-03-2010, 07:38 AM
  4. Very stiff brake pedal?
    By Mesaman4 in forum Brakes/Suspension/Chassis
    Last Post: 01-20-2010, 05:37 PM
  5. low brake pedal
    By johnk in forum Brakes/Suspension/Chassis
    Last Post: 11-15-2009, 07:58 PM
