Thread: High Idle When Starting
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: High Idle When Starting
    To anyone saying 2,000 is normal. You have an issue. Programming is not 2,000 rpm at startup.
    If you'd like to see the table, I'll post them up if you say what year/model you have.
  2. #22 Re: High Idle When Starting
    ok this morning at 5:45am i walked outside and cranked my car up for the first time in 2 days, it was like 50 something, i cranked it up it went to 2k, it didnt stay there it just shot up there for like a sec or 2 then the came down to about 1500-1200 for like 3-4 mins then i started to slowy work its way down but it never went below 1000 even after it was warmed up,
    i tried taking a pic of it with my phone but its a pos
    this was about 5 sec after first start up
    SMGPFC Member #10
  3. #23 Re: High Idle When Starting
    no?
    depending on how cold it is, will depend on how high the rpms are
    Even in the dead of winter the blue car wouldn't idle any higher than 1200-1400 TOPS...and once it gets into closed loop...up to temp or not...625-685.
  4. #24 Re: High Idle When Starting
    well **** idk maybe its a 3100 thing, its done it since the day i got it
    SMGPFC Member #10
  5. #25 Re: High Idle When Starting
    Sure you ain't got a vac leak?
    Or maybe YOUR IAC/TPS' are dirty and need cleaning.
    breh
  6. #26 Re: High Idle When Starting
    everythings clean, it probably has a leak since its a 3100 and they leak to run right
    but for almost 5 years its done the same thing everything time, i would think that if something was wrong then it would get worse over time
    SMGPFC Member #10
  7. #27 Re: High Idle When Starting
    Oct 2011
    Chicago
    When I started mine yesterday it didn't do it, it went straight to 1200 and gave me no issues. Same when I started it when I was leaving where I was at. I'm still going to clean all my sensors and the throttle body, I'm just confused why it would do it a few times and then not do it.
    ((Mine is a 3.8, though I doubt that makes a difference))
  8. #28 Re: High Idle When Starting
    That definately makes a difference. We'll try to help out instead of blaming it on "inferior motor" lol
  9. #29 Re: High Idle When Starting
    SE Level Member popnajera's Avatar
    Aug 2011
    Nw Iowa
    so, should i be concerned mine does that as well?(2000GT 3800) it idles high probably 2k-ish for maybe a minute then drops right down, does it once in the morning and that's it. its cold out though.. weather said "feels like -29" on a side thought i should probably swap to 5-30 now o.O
  1. 98 gtp hard starting rough idle
    By 98BlknSlvrGTP in forum General Tech Discussion
    Last Post: 01-17-2011, 10:10 PM
  2. Need help with my high idle
    By GPMANE97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2010, 09:11 PM
  3. High idle?
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2009, 02:14 AM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  5. fast high low idle
    By gtchris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 04:17 PM
