Thread: High Idle When Starting
Results 1 to 20 of 29
  1. #1 High Idle When Starting
    Oct 2011
    Chicago
    A few days ago I had a new MAF sensor installed in my 2000 Grand Prix GT. It fixed my initial problem, but now when I start my car it idles at about 2000 rpm, and then goes down slowly. I put it into drive and it acts fine, no problems as I'm driving. If I stop it and start it again when it's warm it doesn't do it. I'm wondering if this is a precursor to another problem....
  2. #2 Re: High Idle When Starting
    thats normal, it does that to warm up..
    mainly cause theres ppl that put in drive as the starter is still in gauged and beat on it before the oil has reached the valve train,,
    so it tries to warm up as quick as possible
    SMGPFC Member #10
  3. #3 Re: High Idle When Starting
    no no, 2000 rpms is way too high at first start up.
    normal start up should be at 1200, then slowly down to 900 and finally rest around 680-700 when warm.
    any codes present??
    maybe clean the TPS sensor and IAC sensor on the TB
  4. #4 Re: High Idle When Starting
    no?
    depending on how cold it is, will depend on how high the rpms are
    SMGPFC Member #10
  5. #5 Re: High Idle When Starting
    Jun 2011
    Detroit, MI
    Yea, i think 2000 rpms is pretty high, depends how quickly it drops
    iLoveSpade
  6. #6 Re: High Idle When Starting
    wrong, its set by the computer. cold will just change how long it will stay at said rpms.
    it will never be 2000 rpm ever at start up, if it is, there is somthing wrong,
  7. #7 Re: High Idle When Starting
    Jun 2011
    Detroit, MI
    Well mine jumps up right when i start it and its cold thats normal right?
    iLoveSpade
  8. #8 Re: High Idle When Starting
    wrong again lol
    my car has been sitting for 2 days and its gonna in the 50s when i crank it up, ill take a pic of my tach showing 2k
    SMGPFC Member #10
  9. #9 Re: High Idle When Starting
    Jun 2011
    Detroit, MI
    Mine does what ffdp says, but it jumps up pretty high initially when cold (fuel must flood the engine or something)
    iLoveSpade
  10. #10 Re: High Idle When Starting
    Quote Originally Posted by Hippo Machine View Post
    its suppose to jump straight to 1200ish, completely normal.
  11. #11 Re: High Idle When Starting
    Jun 2011
    Detroit, MI
    So you are saying when its like 40 degrees and your engine has been sitting over night, and you crank (takes about 1.2 seconds for me at that temp i believe) the engine, it starts right up and goes STRAIGHT to 1200? I will get a video of mine in the morn. Cuz mine jumps to 2000 plus
    iLoveSpade
  12. #12 Re: High Idle When Starting
    yeah when its real cold my car will idle at 1200, now with it being in the 50's its idling at 800 in the morning. .....2000 sounds high.
    maybe try cleaning the throttle body and all the sensors.
  13. #13 Re: High Idle When Starting
    First click, starter did like half a turn, cranked right over and bam 1200 rpm.
    2011-10-09194100.mp4 video by Camerongtp24 - Photobucket
  14. #14 Re: High Idle When Starting
    Jun 2011
    Detroit, MI
    Ok so whats that mean when mine goes high right away, then does what yours does?
    iLoveSpade
  15. #15 Re: High Idle When Starting
    that is working fine, straight to 1100-1200 then down. Its adjusting to air temp and coolant temp and other stuff once the info got to the pcm.
  16. #16 Re: High Idle When Starting
    Jun 2011
    Detroit, MI
    OK you don't get what im saying, i will post a vid tomorrow
    iLoveSpade
  17. #17 Re: High Idle When Starting
    its becuase i only skimmed what you said. its shouldnt ever reach that high of revs
  18. #18 Re: High Idle When Starting
    Oct 2011
    Chicago
    It was pretty chilly this morning when I started it, about 50 degrees. It was at about 1200, then went up to 2000, then dropped, and when I drove it to work I had no problems. I started it at work, it did the same thing, put it in drive and no problems. I stopped for gas, and when I started it then it didn't go higher than 1200 and settled in around 800-900. I just don't want it to randomly die on me or something, or maybe I'm overreacting?
  19. #19 Re: High Idle When Starting
    Quote Originally Posted by DrNoodles View Post
    id try cleaning the throttle body up real good, like take it off and remove all the sensors, and clean it. good chance its just sticking a bit and needs to be cleaned.
    for the price of some cleaner and a gasket, you cant go wrong starting there.
  20. #20 Re: High Idle When Starting
    Oct 2011
    Chicago
    Thanks, I'll give that a try tomorrow.
  1. 98 gtp hard starting rough idle
    By 98BlknSlvrGTP in forum General Tech Discussion
    Last Post: 01-17-2011, 10:10 PM
  2. Need help with my high idle
    By GPMANE97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2010, 09:11 PM
  3. High idle?
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2009, 02:14 AM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  5. fast high low idle
    By gtchris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 04:17 PM
