Thread: Little mishap with water....
Results 1 to 11 of 11
  1. #1 Re: Little mishap with water....
    Barksdale AFB, LA
    Quote Originally Posted by snap on View Post
    The motor that you have in there now is not built for a super charger. Do not do it. Your compression ratio is to high right now for a supercharger and you will burn up the motor faster then you can say "**** under the hood" the super charged motors already have a compression ratio that does not need to use a high octane fuel. If you decide to put this on you will need to run a MUCH higher octane in the motor and you will not be capable of running it right.
    How is it that hundreds (that I know of, at least) have done this swap and are able to run it just fine for years? There are several right here on this very forum. It's a very well known and very safe mod as long as the proper tune is loaded. You could probably run a stock GTP PCM if you just do a straight top swap and it would be fine until a more detailed tune was possible.
    2009 Subaru Impreza WRX STI
  2. #2 Re: Little mishap with water....
    GTX Level Member kingd44's Avatar
    Feb 2008
    newyork
    were r u from that u were on the northern state????
  1. Water in Passenger Floorboard [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-31-2012, 07:54 PM
  2. Permanent Water spots?
    By GXPimpin in forum Detailing Tips and Tricks
    Last Post: 10-15-2010, 06:15 PM
  3. Water proof GenV
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 03-12-2008, 08:27 PM
  4. Water Logged Passenger Floor
    By Toofastgs in forum Buick Regal
    Last Post: 01-22-2008, 01:59 PM
