Thread: Little mishap with water....
Results 1 to 11 of 11
  1. #1 Re: Little mishap with water....
    take your time. this is a big job if you dont know hot to build engines. ive learned the hard way a few times.
  2. #2 Re: Little mishap with water....
    GT Level Member duane9586's Avatar
    Apr 2008
    ny
    I have built alot of engines in the past just never done a top swap
    180*, Overkill, K&N, MSD, GEN V, AL 104's,ZZP Shift kit,SD Headers,1.9rr's, 90#,3.2zzp,0KR, 8K HID,Was a Base Model
  3. #3 Re: Little mishap with water....
    PA
    FWIW, just because the engine ingested water doesn't mean the whole thing needs to come apart. First thing I would do is pull the plugs, air filter, etc and crank it over by hand and make sure there is no water in the cylinders. The change the oil to make sure there is no water in it. Then try and crank it and see how it sounds. If all is good, fire it up. I have done this on a couple cars that ingested water and stalled. And with a little careful work, they started up and are still running fine.
    2001 GSE
  1. Water in Passenger Floorboard [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-31-2012, 07:54 PM
  2. Permanent Water spots?
    By GXPimpin in forum Detailing Tips and Tricks
    Last Post: 10-15-2010, 06:15 PM
  3. Water proof GenV
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 03-12-2008, 08:27 PM
  4. Water Logged Passenger Floor
    By Toofastgs in forum Buick Regal
    Last Post: 01-22-2008, 01:59 PM
