Thread: 3.8 engine trouble
Results 1 to 12 of 12
  1. #1 3.8 engine trouble
    Jul 2011
    midwest
    Got a 97 GP with a 3.8 engine. The engine is not running correctly. When I take the air filter housing loose and let the motor draw non filtered air, it sounds and feels like it is struggling to get air. I am also having vaccum pulled through the oil fill cap. When you take the oil cap off,it relieves the motor and the motor no longer acts like it is struggling to draw air,but still doesnt run right. I changed the pcv valve and maf sensor, but nothing changed. The engine isnt running right all the while and I think I may have a clogged cat convertor causing excess preasure in the cylinders. Am I thinking right on this, or does anyone else have any advice on these issues. I am relly scratching my head on this one.
    Thanks
  2. #2 Re: 3.8 engine trouble
    Oil cap issue sounds like a PCV issue.
  3. #3 Re: 3.8 engine trouble
    Sep 2011
    victoria
    do a vacume test
    find out what your vacume is that will tell you if you have a clogged cat because if it is clogged cat you wont have any vacume.
  4. #4 Re: 3.8 engine trouble
    Quote Originally Posted by vern85 View Post
    do a vacume test
    orly?
    If he had NO vacuum, the motor wouldnt even run home boy.
  5. #5 Re: 3.8 engine trouble
    try another pcv valve and make sure you replace both the o rings.
    If he has a clogged cat, the car would still have vacuum ( IT ALWAYS HAS VACUUM WHILE RUNNING) but would have access back pressure.
    To test this either take the up stream o2 sensor out and go drive the car and see if it runs better or, take the sensor out and put a pressure gauge into the o2 bung and read the pressure. If it reads more than 1-2 psi, the cat is more than likely clogged. Modern day cars make less than 1 psi of back pressure.
  6. #6 Re: 3.8 engine trouble
    Sep 2011
    victoria
    back pressure test is by far the most acurate but a vacuum test is good to and is easier hook a vacuum tester up to manifold vacuum. watch at idle the vacuum, if the needle drops near zero when the engine is accelerated rapidley and then rises slightly to a reading below normal indicates that you have a restiction in the exaust HOME BOY
  7. #7 Re: 3.8 engine trouble
    MO
    No one is going to take you seriously with your first grade spelling.
    <brandonl2000> LMAO D!!
  8. #8 Re: 3.8 engine trouble
    SE Level Member chev1988rolet's Avatar
    Jul 2010
    TX
    this probably wont be your fix but its worth a try. i worked on a vehicle that had vaccum at the oil fill cap and it turned out to be a cracked head. do a compression test and find out. or you could also just take off valve covers on both banks, remove all spark plugs and connect a compressor hose into each sp hole while both valves closed ( both pushrods at the lowest point of their travel. you should hear hissing when u apply air. engine might spin when u apply air so keep ur hands away from moving parts
  9. #9 Re: 3.8 engine trouble
    Jul 2010
    TX
    also, you might hear hissing on the exhaust manifold or the intake manifold. thats just due to slight worn out valves or carbon deposits. you will also hear hissing at oil pan small amounts is normal but it shouldnt be to excessive unless you have real bad piston rings or a broken compression ring
  10. #10 Re: 3.8 engine trouble
    That type of vacuum pull is either pcv missing o-ring on the cap or under/on the valve. Or .. we not too long ago saw a missing LIM bolt that allowed this same type of issue.
  11. #11 Re: 3.8 engine trouble
    Jul 2011
    midwest
    LIM-is that short for lower intake manifold?
  12. #12 Re: 3.8 engine trouble
    yes
  1. Engine trouble?
    By DCGTP in forum General Tech Discussion
    Last Post: 01-25-2012, 01:57 PM
  2. Engine Trouble
    By 98GTFan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-10-2011, 03:58 PM
  3. Engine Trouble!! need help!
    By ddrum in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-12-2010, 04:41 PM
  4. S/C Trouble...
    By LaCabra in forum General Tech Discussion
    Last Post: 04-01-2009, 09:45 PM
  5. engine light/trouble codes
    By Jakegday in forum General Tech Discussion
    Last Post: 01-02-2009, 08:03 PM
