Thread: 03 GT coolant drain Valve?
Results 1 to 4 of 4
  1. #1 03 GT coolant drain Valve?
    Jul 2010
    Philly
    So I just replaced my coolant elbows and now I want to give her a good flush. Right now the rad is full of distilled water but for the life of me cant find the drain valve on this car. Where the heck is it? Pics?
  2. #2 Re: 03 GT coolant drain Valve?
    drivers side on rad.
    or remove lower rad hose.
  3. #3 Re: 03 GT coolant drain Valve?
    It's called the petcock...and keep in mind it is easy to strip out as well since it is a little piece of plastic.
    Genius GM.
  4. #4 Re: 03 GT coolant drain Valve?
    Pennsylvania
    Definitely just pull the lower rad hose, so much quicker...
    I struggled with finding the petcock and wasted a lot of time for nothing, pulled the lower rad hose and the entire thing was drained in less than 3 minutes.
    Sport Edition Kv5 18x8
  1. I think my AC drain is plugged ?
    By Y2KGTP in forum General Tech Discussion
    Last Post: 04-18-2011, 12:40 PM
  2. transmission drain
    By mhartwig in forum General Tech Discussion
    Last Post: 11-22-2010, 07:40 PM
  3. radiator drain o-ring size? FAILED motormite drain.
    By alacran in forum General Tech Discussion
    Last Post: 04-03-2010, 08:16 PM
  4. help! - oil drain plug
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2010, 05:27 PM
  5. Oil drain plug
    By SlowM90 in forum General Tech Discussion
    Last Post: 12-22-2009, 12:05 PM
