Thread: Blown Intake Gasket?
Results 1 to 17 of 17
  1. #1 Re: Blown Intake Gasket?
    PA
    Quote Originally Posted by TDgrand View Post
    When you say 60/40ish does that mean 60%coolant and 40% water?
    I am going to flush my system then replace the LIM. With how much water is left in the engine after the LIM, how do I determine how much coolant to add?
    Thanks.
    All depends on where you live. You need to mix your coolant so it will not freeze at the lowest temperature in your area. You should buy something like this:
    Amazon.com: Prestone AF1420 Professional Antifreeze / Coolant Tester: Automotive
    and test the coolant when you mix it before you put it in your engine. I mix mine to around -30 to -40°F. That is safe for my area. If I lived farther north, I would probably have to adjust that a little. I think most will tell you not to go over 70%coolant/30% water.
    2001 GSE
  2. #2 Re: Blown Intake Gasket?
    Jul 2010
    Philly
    Thanks guys. Right now I got 100% water. I'm on my 4th flush. What I do is drain and fill with 100% water drive for a few days and repete. Now that we got snow on the ground I better get some green stuff in there! Ill drain the rad and fill with coolant then test it. Ill shoot for -20.
    Thanks for the help guys. All is well
  1. Blown Head Gasket??
    By InOuterSpace in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-28-2011, 08:01 PM
  2. Blown head gasket?
    By tjhgtp86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2010, 04:01 AM
  3. low, very low oil. blown head gasket or something else?
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 01-04-2010, 03:51 PM
  4. blown head gasket
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-09-2009, 12:18 AM
  5. Possible Blown Head Gasket
    By Blk99GpGt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-09-2009, 12:40 PM
