Check engine light on? any codes? Could be just a needed tune up and bad mounts.
I would say plugs/wires, replace the fuel and air filter, clean the MAF and check for vacuum leaks then see what you get.
Just stick w/ stock plugs and wires. No need to get super duper quintillion platinum plugs. I personally run NGK V-Power TR55's and have yet to have and issue. Also stock Delco wires from the dealer.
