Thread: Mass air sensor Need help
Results 1 to 13 of 13
  1. #1 Mass air sensor Need help
    Jul 2011
    Michigan
    Today on the way home from work my fiance said her check engine light came on and 3 minutes later the car stalled. She started it back up and drove for about a mile and it stalled again. She was able to get the car to auto zone where they ran a code check and sais it was the mass air sensor. My question is how hard it it to change and whats does it look like? Thanks for the help!
  2. #2 Re: Mass air sensor Need help
    That kinda depends Johnny.. what does she drive for a car?
    You may be thinking that I'm putting that bluntly, I am.. but it's kinda necessary info to help you locate the part you are looking for.
  3. #3 Re: Mass air sensor Need help
    Jul 2011
    Michigan
    Im sorry its a 2001 GP GT
  4. #4 Re: Mass air sensor Need help
    The mass air flow sensor is right on top of the throttle body. Two screws (usually torx) hold it to the TB.
  5. #5 Re: Mass air sensor Need help
    Jul 2011
    Michigan
    I think I saw it. is it a little square black box?
  6. #6 Re: Mass air sensor Need help
    Yup...and to verify that its really bad...unplug it and start the car and see if the dying issue goes away. Then while it is idling...plug it back in. If the car sputters and dies...its your MAF.
  7. #7 Re: Mass air sensor Need help
    Jul 2011
    Michigan
    Alright will do. I cant believe that little plastic piece is $159
  8. #8 Re: Mass air sensor Need help
    Jul 2011
    Michigan
    Ok went out and unplugged the MAF started car let it idle for 2 minutes and all was great. Plugged it back in and about 20 seconds later it started to idle down and almost died. So im assuming thats the problem?
  9. #9 Re: Mass air sensor Need help
    Yup...first things first, try some MAF cleaner. It's like 5 bucks. And its close to the brake cleaner at your local auto parts store.
  10. #10 Re: Mass air sensor Need help
    Jul 2011
    Michigan
    will do thanks!
  11. #11 Re: Mass air sensor Need help
    Upstate SC
    I tried cleaning mine, (97 GP GT) and it helped for about a week and 1/2. But in the end I had to empty the wallet out for that little black square.
  12. #12 Re: Mass air sensor Need help
    Junkyards have them for much less BTW
  13. #13 Re: Mass air sensor Need help
    THIS.
    Or, Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
  1. mass air flow sensor?
    By Bakerdd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2012, 10:35 AM
  2. mass air sensor bad?
    By Regalgs98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2011, 10:50 PM
  3. Which of the following is the MASS AIR FLOW sensor that I need on my 98 GTP?
    By vanels in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2010, 10:22 AM
