Thread: small ticking when cold?
Results 1 to 16 of 16
  1. #1 small ticking when cold?
    SE Level Member 04GT's Avatar
    Sep 2011
    Brown City, MI
    hey guys 2005 GP GT1 3800 NA.
    notice a SMALL ticking noise when its cold. (sits in garage all night, start in AM) starts, runs, perfectly fine. no issues. goes away a mile or two down the road. or if i let it idle for a while in the garage. what the heck is it? gets faster with RPM's.
    thanks for any input.
    04 GP GT, dual borla exhaust, 24x4.5in tips, 18'' rims, audiobahn system, tinted 5%, windshield 35%, tinted tails, AVS HL covers
    MSD super conductor plug wires, autolite 606 plugs, shift kit,10k HID Low's, 8k HID High's, 8k HID Fog's
  2. #2 Re: small ticking when cold?
    prolly some lifter tick.
  3. #3 Re: small ticking when cold?
    Sep 2011
    Brown City, MI
    normal? or needs tightening?
  4. #4 Re: small ticking when cold?
    its kinda common to have some lifter tick and or fuel injector tick/noise.
  5. #5 Re: small ticking when cold?
    GTX Level Member bandits grand prix's Avatar
    Jul 2010
    connecticut
    did u just start it and drive away? cuz my cousin said for mine that the oil didnt get to it yet. (whateverpart he said i was spacing)
  6. #6 Re: small ticking when cold?
    Sep 2011
    Brown City, MI
    Quote Originally Posted by bandits grand prix View Post
    when i do that, it goes away. when i start it and let it run it gets quieter and wears off. maybe pull the tappet and check em all for torque?
  7. #7 Re: small ticking when cold?
    Jul 2010
    connecticut
    Quote Originally Posted by 04GT View Post
    No idea what that is.
  8. #8 Re: small ticking when cold?
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    tappet as in valve?
  9. #9 Re: small ticking when cold?
    i had a lifter clapping a while back when i went a quart low on oil, topped off with 40 weight oil, it stopped doing it 3 days later. ( it had done it a few times like 5 or 6 ticks and stop in the past, here and there) hasn't done it since, been a few months now.
    from when i did my own searching about lifters ticking, everyone says it completely normal if it goes away with in a few minutes, thicker oil should help tho.
  10. #10 Re: small ticking when cold?
    Jun 2011
    Detroit, MI
    Thank you! I was about to ask this same question.
    iLoveSpade
  11. #11 Re: small ticking when cold?
    Depending on what your running...
    When I first built my motor I was running 20w-50 Valvoline VR1.
    I still now run 10w-40...thicker weight + extra zinc properties = good for the bearings and for sure makes for a quieter engine.
    Also, with an aftermarket intake...your going to hear the motor more.
  12. #12 Re: small ticking when cold?
    Sep 2011
    Brown City, MI
    take it to dealer. hes says pop your hood, leave it running. i pop it, he grabs a spray bottle, and sprays the belt. INSTANTLY stops ticking and no noises at all are coming out. he says belts dirty. closes the hood. lmao. my motor is quiet as a kitten now
  13. #13 Re: small ticking when cold?
    Dec 2011
    United States
    Might be a moot point by now, but I had another solution. My '02 ticked at startup after the first oil change, which was in cold weather. A service tech at the dealer said that AC-Delco oil filters have a check valve that keeps a certain amount of oil in the upper regions on shutdown, and that other filters don't have it. I had used a FRAM. I changed to an AC-Delco right away and it stopped, never to recur in 150K miles since then.
    About that same time I had changed the oil and filter (FRAM, on sale, had always used AC-Delco) in our '98 Montana, and it began to tick even when the engine warmed up, in cold weather. Switched back to AC-Delco and it's never done it since then, with 221K and counting.
    For what it's worth.
  14. #14 Re: small ticking when cold?
    Jun 2011
    Detroit, MI
    If thats worked for you, great. But I don't see how an oil filter can defy gravity.
    iLoveSpade
  15. #15 Re: small ticking when cold?
    Pennsylvania
    Quote Originally Posted by Hippo Machine View Post
    SOMEBODY didn't do their Fram Challenge.
  16. #16 Re: small ticking when cold?
    Donating Users joshuaandrew92's Avatar
    Jul 2010
    Bluffton, IN
    It's your hydraulic lifters ticking. Mine does the same thing. What happens is when your engine is off for long periods of time, your lifters dont hold the oil pressure they need when they start moving again. So they make a ticking noise when they start moving again until they fill back up with oil. I suggest using a quart of Lucas Oil Stabilizer when you do your next oil change. It is a thicker, pure petroleum based oil additive that does not completely run back into the oil pan after shut down. Therefore there's a lot greater chance you wont have another dry start/not as much lifter noise/no lifter noise. I've also been told, not saying its true, but once you hear this noise your lifters are pretty much ready to be changed. Hope it helps some...
  1. ticking at cold start...
    By twol8uluz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2011, 10:01 AM
  2. Small oil leak
    By Storm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2010, 08:55 AM
  3. New small appearance mod..
    By Injun #4 in forum Visual/Body Modifications
    Last Post: 03-31-2009, 11:49 PM
  4. Small battery
    By Arkanzan Wheeler in forum General Tech Discussion
    Last Post: 05-24-2008, 10:33 PM
  5. too small of a s/c belt???
    By IndeedSS in forum General Tech Discussion
    Last Post: 03-31-2008, 03:06 PM
