Thread: Car running bad, unsure if trans or engine
Results 1 to 19 of 19
  1. #1 re: Car running bad, unsure if trans or engine
    SE Level Member BigDon03's Avatar
    Aug 2011
    Indiana
    I drove for about an hour, no codes hit. I'm going to clean the MAF tomorrow, amd make an appt. to get my cat replaced this week.
  2. #2 re: Car running bad, unsure if trans or engine
    dont just assume the cat is bad yet.
    You should do tests befor you just assume stuff.
    take the upper o2 sensor out and take the car for a short drive, yes it will be loud like a tractor and will throw a code, if the car runs better when doing this test it show that the cat is plugged up because the o2 hole is open its letting all the gases that cant normally escape get out.
  3. #3 re: Car running bad, unsure if trans or engine
    SE Level Member jarkayman's Avatar
    Aug 2011
    CNY
    This^^
  1. Running only a trans cooler?
    By Z34Phoenix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-29-2011, 08:34 PM
  2. so first mod today (lil unsure)
    By krimsonwolf in forum General Tech Discussion
    Last Post: 09-23-2010, 09:48 PM
  3. 1993 3.1 running problems could be trans
    By ronaldgtp in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 10-28-2009, 08:16 PM
  4. new here and unsure what to do
    By kittie1342 in forum Introductions/Noob Questions
    Last Post: 05-23-2009, 03:12 AM
  5. Running Trans oil as engine oil
    By 04CompG in forum General Tech Discussion
    Last Post: 11-25-2008, 12:09 AM
