Thread: Fuel tank is 12-13 gallons?
Results 1 to 20 of 26
  1. #1 Fuel tank is 12-13 gallons?
    GT Level Member Xanthous's Avatar
    Apr 2011
    St. Louis
    Everytime I fill up, the pump says around 11-12 gallons. What does this mean? Non-stock tank? I thought these cars had 17 gallon tanks. I have an '00 i bought about 6 months back.
    Edit; I have a gtp if you want to move this, but it shouldn't matter.
  2. #2 Re: Fuel tank is 12-13 gallons?
    17.5 is stock
    SMGPFC Member #10
  3. #3 Re: Fuel tank is 12-13 gallons?
    Apr 2011
    St. Louis
    17.5 is stock
    right, so interesting...i guess there's an aftermarket one on mine. You can put smaller ones on? Fuel gauge works correctly, don't think the dic works accurately though.
  4. #4 Re: Fuel tank is 12-13 gallons?
    Houston
    Your gas gauge level is prolly off.
  5. #5 Re: Fuel tank is 12-13 gallons?
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    gm says theres like 3 gallons still in tank when light comes on.
  6. #6 Re: Fuel tank is 12-13 gallons?
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    yea the gauge is just off I used to never put more in than 10 gallons on e and then one day It took 14 gallons
  7. #7 Re: Fuel tank is 12-13 gallons?
    Apr 2011
    St. Louis
    this it could be, is there any way to fix that?
  8. #8 Re: Fuel tank is 12-13 gallons?
    Houston
    Dont quote me, but I think the level is mounted to the fuel pump. Not really sure how you'd adjust it. But I know you can....lol
    *EDIT: After doin some reading, people are saying you need to replace the sending unit on the pump.
  9. #9 Re: Fuel tank is 12-13 gallons?
    Jul 2011
    Michigan
    yes, its on the pump. haynes manuale warned to be careful because its easy to bump and then the level is off.
  10. #10 Re: Fuel tank is 12-13 gallons?
    Apr 2011
    St. Louis
    hmm, alright. I'll take replacing it into consideration. If it was bad, it would still display full tank when the tank was full?
  11. #11 Re: Fuel tank is 12-13 gallons?
    Houston
    It may be reaching full before its actually full
  12. #12 Re: Fuel tank is 12-13 gallons?
    How many miles do you get to a tank? just wondering.
    The float normally is not the issue, its the fuel level sensor that moves back and forth (aka up and down) with the float on the fuel pump.
    On this small sensor/ electrical flied thing are 2 small prongs things with teeth on them, those make contact with the sensor and thus give you the reading on the gauge. Over time the teeth wear down and start to give false readings and kinda glitch the sensor.
    You can replace the part with the teeth and have new teeth always be in contact with the sensor.
  13. #13 Re: Fuel tank is 12-13 gallons?
    Apr 2011
    St. Louis
    Gotcha, thanks five.
    I'm not exactly sure but i just filled up tonight so I'll reset my trip odometer in the morning. If there's a way to find out if the gas gauge isn't reading correctly I'd want to try it.
  14. #14 Re: Fuel tank is 12-13 gallons?
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    A better question would be do you fill up as soon as the light comes on? If so or close to it then thats about right but if you push it past and the needle down below E then it should be taking more. I have a 98 which has a gallon bigger tank and when the light comes on and I fill up I can typically put around 14 gallons in meaning there is still 4 more gallons left in mine.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  15. #15 Re: Fuel tank is 12-13 gallons?
    Apr 2011
    St. Louis
    Specifically which light? the low fuel on gauges?
    usually that doesn't come on, i usually fill up when the dic flashes low.
  16. #16 Re: Fuel tank is 12-13 gallons?
    Feb 2010
    Oklahoma City, OK
    Quote Originally Posted by Xanthous View Post
    Yes, BAM! In my experiences, where your filling up and the gallons you report are about right. Just know that if you had to you could go a good deal further. I took my GT 74 miles after the light came on, never ran out. It always averaged 18.5 mpg's too. Now I have a good job and gas up more often so I haven't had a chance to see how far the GTP will go. Maybe since I'm switching to e85 soon that's how I will run the gas outta my car and just carry a 5 gallon jug of e85 and my laptop to flash the e85 tune.
  17. #17 Re: Fuel tank is 12-13 gallons?
    Pensacola, FL
    I have a 97 GT with an 18 gallon tank. I get 20mpg on average with 93octane, and avg 280-290miles before my gauge shows E. I know that I can get 340-350miles, but have yet to push it beyond 325mi.
  18. #18 Re: Fuel tank is 12-13 gallons?
    Florida
    Lately ive let it get closer to E only cuz i want to extend my fuel milage as much as i can and when i refill its usually reading 15-15.5 gallons. Otherwise my gas milage has increased nicely from when i was stock. Getting at least 40-50 miles more per tank plus im drivin with less lead foot too.
  19. #19 Re: Fuel tank is 12-13 gallons?
    Pennsylvania
    Quote Originally Posted by dmahlikGT View Post
    Nothing says lovin' like burning out your fuel pump.
  20. #20 Re: Fuel tank is 12-13 gallons?
    Florida
    I dont let it get down near empty all the time.Prob the last 3-4 fillups out of the hundreds of times ive filled up.Plus sooner or later im gonna change out the pump anyway.
  1. Drop Fuel Tank
    By roundbox52 in forum General Tech Discussion
    Last Post: 07-15-2023, 08:43 PM
  2. draining the fuel tank
    By kavaman in forum Introductions/Noob Questions
    Last Post: 07-24-2011, 07:22 PM
  3. Fuel Tank Sensor going bad
    By GAFF in forum General Tech Discussion
    Last Post: 04-04-2011, 09:40 PM
  4. How many gallon fuel tank
    By kjclawson in forum General Tech Discussion
    Last Post: 11-13-2009, 06:30 PM
  5. fuel tank capicity
    By whiteknuckle in forum General Tech Discussion
    Last Post: 01-19-2009, 07:44 PM
