Thread: l26 ticking noise...
Results 1 to 10 of 10
  1. #1 l26 ticking noise...
    Chilliwack BC
    08 grand prix base. 129,000 km
    here's a question...i hear alot of what sounds like chain slap or valvetrain noise from my car. usually under load at low rpm's. hearing it alot more often since doing the intake...is it normal?
    i haven't put any ears on the motor to determine where the noise is from yet. no stored codes, no misfires or anything like that. could it even be the injectors i'm hearing?
    As far as maintence done i have run fuel system/injector cleaners every 40,000km, and cleaned my TB at the same intervals. oil has always been changed every 6000km and has been run on synthetic since 35000km.
  2. #2 Re: l26 ticking noise...
    Kansas
    Yes dude.... PLEASE READ OTHER THREADS.
    On these engines when you put an open filter on it, you can hear the top end chatter more. I had the same thing, as have others.
  3. #3 Re: l26 ticking noise...
    Time to buy a stethescope, pinpoint it and then determine if it's a problem.
  4. #4 Re: l26 ticking noise...
    Chilliwack BC
    Quote Originally Posted by NegativeOne13 View Post
    I swear i did look around and i'm going to have a listen tonite going to borrow a tech's steth from work.
  5. #5 Re: l26 ticking noise...
    Well yeah...the factory intake systems are quiet as hell really.
    These are loud, clattery motors...get used to it. Running an aftermarket intake will really make you hear the noise...
  6. #6 Re: l26 ticking noise...
    Never Never Land
    Ya after doing an intake on my step mom's gtp it got freakin loud. It's probably normal couch.
  7. #7 Re: l26 ticking noise...
    top 5 dead or alive OmegaRed's Avatar
    Feb 2010
    Medford, Oregon, United States
    yeah couch, same case in mine, same year/model.. since i did my intake i hear it under accelleration, i assumed it was knock because when i run premium it seems to happen less
    but who knows lol
    btw my car is at 63k miles
  8. #8 Re: l26 ticking noise...
    Chilliwack BC
    Scoped it last night. def not coming from the t-chain area at all. can hear it mostly from uim area so ima just leave it. like said above it's prob normal. if she gets louder i'll worry about it.
    rattle rattle rattle
  9. #9 Re: l26 ticking noise...
    SE Level Member Wisconsingrandprix's Avatar
    Aug 2011
    roun here
    is it you supercharger??
    check for play on the pulley
  10. #10 Re: l26 ticking noise...
    Feb 2010
    Quote Originally Posted by Wisconsingrandprix View Post
    the twinz iz not supercharged
  1. what is this ticking noise?!?!?
    By 2000gpgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2011, 07:36 AM
  2. ticking noise
    By SCbuick010 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2011, 10:52 PM
  3. ticking noise from engine
    By sca555 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2011, 05:53 AM
  4. Lifter/ticking noise???
    By kind153 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-24-2010, 12:43 PM
  5. ticking noise???????
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 10-02-2008, 12:27 PM
