Thread: Small Coolant Leak - Any Ideas?
Results 1 to 8 of 8
  1. #1 Small Coolant Leak - Any Ideas?
    Jun 2011
    Detroit, MI
    While I was putting in the HID's yesterday, I saw a couple of green drips hanging down underneath the radiator. It doesn't drip when sitting still, just kind of hangs there. I haven't noticed a drop in coolant in the last few weeks, so not a big deal as far as I knowm but would like to fix it soon. Here is a picture so you can please help me diagnose it, thanks:
    iLoveSpade
  2. #2 Re: Small Coolant Leak - Any Ideas?
    check to make sure the drain is tight on the bottom of the radiator
  3. #3 Re: Small Coolant Leak - Any Ideas?
    Omaha, NE
    If it is tight and still drips, take the plug off, add some teflon tape around the threads and put it back on.
    CAUTION: DON'T OVERTIGHTEN THE PLUG! IT WILL STRIP!
  4. #4 Re: Small Coolant Leak - Any Ideas?
    Kansas
    You know what else strips right?
  5. #5 Re: Small Coolant Leak - Any Ideas?
    Pennsylvania
    Bacon!
    But seriously, if you want to know if you have a leak, you can always park on top of a big sheet of butcher paper.
  6. #6 Re: Small Coolant Leak - Any Ideas?
    Omaha, NE
    Quote Originally Posted by NegativeOne13 View Post
    The lovely ladys that we will be visiting in KC?
  7. #7 Re: Small Coolant Leak - Any Ideas?
    Quote Originally Posted by SlowNA06 View Post
    what's wrong with a clean spot in the driveway or ... cardboard? Cause I don't have any butcher paper.
  8. #8 Re: Small Coolant Leak - Any Ideas?
    Pennsylvania
    Absolutely nothing. Unless you don't have any clean spots in the driveway.
  1. Exhaust leak, need ideas
    By Dtrick22 in forum General Tech Discussion
    Last Post: 08-25-2010, 10:08 PM
  2. Small oil leak
    By Storm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2010, 08:55 AM
  3. Broken Thermostate Bolt & small coolant leak ?!?!?
    By FlaminWhite97GTP in forum General Tech Discussion
    Last Post: 02-15-2010, 07:32 PM
  4. Could a small valve cover leak cause a loss of boost on a PCV equipped vehicle?
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2009, 11:57 AM
  5. evaporative systerm leak(small)
    By MARKS99 in forum General Tech Discussion
    Last Post: 04-20-2009, 10:56 PM
