Thread: Stumped with P0300 code
Results 1 to 8 of 8
  1. #1 Stumped with P0300 code
    May 2011
    ohio
    ok i have a p0300 code coming on i have changed the spark plug the wires and checked the egr and coil packs they are both good.
    have any idea why this is happen just started out of know where
  2. #2 re: Stumped with P0300 code
    Omaha, NE
    Have you checked or replaced your spark plugs?
    What about your o2 sensor?
    What about your injectors?
    OBD-II Trouble Code: P0300 Random/Multiple Cylinder Misfire Detected
  3. #3 re: Stumped with P0300 code
    May 2011
    ohio
    yep and it is pumping fuel in to the cyclered but its not running so i dont think it a injector
  4. #4 re: Stumped with P0300 code
    Did you gap the plugs?
  5. #5 re: Stumped with P0300 code
    May 2011
    ohio
    yep
  6. #6 re: Stumped with P0300 code
    Unplug the MAF sensor and give it a try.
    OR.
    If it is just cranking...you prolly need to have the ICM tested...because that'd be the next thing. It's what the coil packs sit on.
  7. #7 re: Stumped with P0300 code
    May 2011
    ohio
    we tested that. im going just put it in the shop
  8. #8 Re: Stumped with P0300 code
    Nov 2011
    louisville ky
    did u figuer it out i have a 2005 gtp that is doing the samething
  1. Random Misfiring P0300 Code
    By spcguy88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2010, 09:44 PM
  2. Check engine code: P0300?
    By CSteen85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-02-2010, 11:45 AM
  3. Sputtering and P0300 code
    By grngt97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 02:12 PM
  4. Code P0303, and p0300
    By Progas in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2009, 09:08 AM
  5. P0300 multiple cylinder misfire code
    By Reeddawgy in forum PCM Tuning
    Last Post: 07-15-2008, 07:42 PM
