Thread: need help figuring out how to replace drivers side engine bracket
Results 1 to 2 of 2
  1. #1 need help figuring out how to replace drivers side engine bracket
    Aug 2011
    United States
    just as the title says, i cant figure out how to get the bolt on the bottom of the brackett off, there is something in the way and i cant get around it
  2. #2 Re: need help figuring out how to replace drivers side engine bracket
    Feb 2008
    Are you talking about the aluminum mount bracket that is bolted to the head? If so, the coolant temperature sensor is in the way of getting a socket and ratchet on the lower bolt. You will probably have to drain some coolant out and remove the sensor so that you can get the bolt out.
  1. AC blows Ice Cold on the Passengers Side and warm on the Drivers Side.
    By rynoman03 in forum General Tech Discussion
    Last Post: 08-08-2011, 11:18 PM
  2. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
  3. Window Regulator + Bracket, are drivers 2 dr and 4dr the same?
    By Quicklynx in forum Visual/Body Modifications
    Last Post: 07-14-2009, 06:21 PM
  4. front drivers side sits higher than passengers side
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 06:21 PM
