Thread: 04 Grand Prix starting issue...
Results 1 to 5 of 5
  1. #1 04 Grand Prix starting issue...
    Donating Users joshuaandrew92's Avatar
    Jul 2010
    Bluffton, IN
    I just bought the 04 grand prix GT today (3800 series 3 n/a) , and sometimes it has a problem after sitting a while with starting.
    If I let it sit for a little bit i have to cycle the key a few times before it will start and stay running, or i have to start it and put my foot into the pedal before it stays running. I'm just a little concerned about this and curious about what could cause it.
    My mind is telling me that theres something wrong with the fuel delivery to the engine which is causing this issue. But once it starts it stays running fine.
    Just a little confused, any help is appreciated. thanks
  2. #2 Re: 04 Grand Prix starting issue...
    Indianapolis
    I had the same problem as you. Most likely you just need to clean the throttle body because it gets alot of engine gunk on it over time. Just pick up some throttle body cleaner from an auto store then take it off the car and go to town on it.
  3. #3 Re: 04 Grand Prix starting issue...
    Quote Originally Posted by TheNoob23 View Post
    This.
    The noob is right...plenty of DBW cars suffer from build of in the TB's...deleting the EGR also vastly helps with that.
  4. #4 Re: 04 Grand Prix starting issue...
    Jul 2010
    Bluffton, IN
    Ok thank you both I will try that tomorrow! Will post the results when I get them...
  5. #5 Re: 04 Grand Prix starting issue...
    SE Level Member Freaze's Avatar
    Atlanta
    Any word on if this worked for you? Seem to have the same issue with my 04
  1. 2000 Grand Prix GT- not starting
    By grneyes908 in forum General Tech Discussion
    Last Post: 03-19-2015, 11:25 AM
  2. 01 grand prix starting problems
    By jerrynorman in forum General Tech Discussion
    Last Post: 04-23-2011, 10:08 AM
  3. 92 Grand Prix SE starting problem
    By Jhowie in forum General Tech Discussion
    Last Post: 03-17-2011, 09:24 PM
  4. 2002 Grand Prix Starting Issue.
    By Honchop1 in forum General Tech Discussion
    Last Post: 11-10-2010, 08:35 PM
  5. 2001 Grand Prix Starting Issue
    By Badley in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-24-2010, 10:12 PM
