Thread: Identify this sound?
Results 1 to 20 of 24
  1. #1 Re: Identify this sound?
    sounded nor at first but in the revs it sounded it a lifter or maybe a valve?..
    not sure
    SMGPFC Member #10
  2. #2 Re: Identify this sound?
    Kansas City, MO
    I was thinking that. If you listen close at first its knocking. Just not alot I assumed the lifters moved alot. The cylinder does seem to hold compression.
  3. #3 Re: Identify this sound?
    that sounds like a rod knock and a lifer/rocker clapping away.
  4. #4 Re: Identify this sound?
    Kansas City, MO
    Is there anything I can do to see if its one or the other?
  5. #5 Re: Identify this sound?
    spun bearings would make the oil all full of sparkles, pull the dip stick and see what it looks like.
  6. #6 Re: Identify this sound?
    Kansas City, MO
    I pulled the dipstick and the oil looks normal. Only has about 1000 miles on it. wiped it off with my fingers and did not notice anything in it.
  7. #7 Re: Identify this sound?
    SE Level Member tgarison's Avatar
    Abilene, Tx
    I agree that sounds like a rod knock to me.
  8. #8 Re: Identify this sound?
    Kansas City, MO
    I am going to test the valves tonight when my friend comes over. If it is rod knock I am assuming my only options are rebuilding or swapping in another motor?
  1. Identify this harness
    By SnowDrift in forum General Tech Discussion
    Last Post: 12-12-2010, 09:23 PM
  2. Identify this GTP
    By offroadfury6 in forum 04+ Specifics
    Last Post: 11-07-2009, 02:31 AM
  3. Help identify
    By ErichK in forum Visual/Body Modifications
    Last Post: 08-06-2009, 10:48 PM
  4. help me identify this sound please!
    By kyle99gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2008, 11:08 AM
