Thread: Air Conditioner Not Turning On
Results 1 to 9 of 9
  1. #1 Re: Air Conditioner Not Turning On
    Kansas City, MO
    You can jumper the low pressure switch and if it engages then your low on charge.
  2. #2 Re: Air Conditioner Not Turning On
    Jul 2011
    I have this same problem. How do you jumper the low pressure switch? Where is it located? What are the steps? I have NO experience with with stuff.
  3. #3 Re: Air Conditioner Not Turning On
    Pennsylvania
    Just buy a can with a gauge and use the gauge to check the pressure at the low side port before you pucture the can.. the compressor has a sensor that wont let the clutch engage if the pressure is too low in the system.
    If it turns out that the refrigerant pressure is not your problem, just return the can and gauge as you didnt puncture the can yet.
    Sport Edition Kv5 18x8
  1. 05 GP Air Conditioner Not blowing cold anymore
    By mpoynter31 in forum General Tech Discussion
    Last Post: 05-19-2012, 06:53 PM
  2. Car wants to die while turning
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2011, 10:32 AM
  3. Turning a 01' SE into a GT
    By Dangerous313KidInAPrix in forum Visual/Body Modifications
    Last Post: 03-03-2009, 09:17 PM
  4. air conditioner compressor
    By justwhisen in forum Shops and Community Heroes
    Last Post: 09-03-2008, 07:29 AM
  5. TCS not turning off
    By Keet04GTP in forum General Tech Discussion
    Last Post: 08-06-2008, 02:57 PM
