Thread: 98 L36 LIM gasket question
Results 1 to 5 of 5
  1. #1 Re: 98 L36 LIM gasket question
    Charles City, IA
    you can cut off the pins if your block does not have holes for them.
    SMGPFC Two Nipple General
  2. #2 Re: 98 L36 LIM gasket question
    Jul 2008
    Nashville, TN
    Some creative searching found the info I needed.
    A question was asked and I figured I'd toss this out in the open as well for general info to all.
    When ordering LIM gaskets on the 3800, there are two listings.
    First design w/o locating pins
    Second design with locating pins
    Soooo what's a locating pin right? On the second design there are two rubber pins on the rubber end seals of the LIM gasket set. 96-97 year engine blocks are technically are the first design w/o pins. 98+ are second design blocks. The difference is not worthy of having two different sets of gaskets. IMO the second design should have superceded the first and only one version should be available as the pins and their function is minimal at best.
    96-97 engine block. Look at the top and bottom of the picture at the block. See the solid line of the block from head to head. That's the first design w/o any holes for locating pins to sit into.
    98+ engine block. Look at the left and right ends of the block. See the two holes on each end. These are where the locating pins sit into.
    When putting second design gaskets on a 96-97 block the pins simply lay over the side and still do the job of holding the gasket in place before the LIM is put back on.
    Aluminum gaskets may be available in both first and second design. Keep in mind that first/second design does not signifiy aluminum vs plastic.
  3. #3 Re: 98 L36 LIM gasket question
    That stuff looks famiilar. Glad it could help.
    Nick..the pins hang over on the old blocks and you won't need to cut them at all. Which is why I typically tell eveyone buy the second design, you can't lose.
  1. Oil Pan Gasket
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 12-31-2011, 07:07 PM
  2. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  3. GM Gasket Kit
    By Spartan GL in forum General Tech Discussion
    Last Post: 01-22-2010, 02:17 PM
  4. Gasket Kit
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2009, 01:09 PM
  5. Head Gasket Question
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 11:31 PM
