Thread: SES for Bank 1 too rich?
Results 1 to 8 of 8
  1. #1 SES for Bank 1 too rich?
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    I got an SES code P0148 (I think it was if I remember right) was for bank 1 being too rich......solutions?
  2. #2 Re: SES for Bank 1 too rich?
    Charles City, IA
    Find why you are running rich and correct that issue, could be a stuck injector, bad maf, dirty air filter, spark plugs you name it.
    SMGPFC Two Nipple General
  3. #3 Re: SES for Bank 1 too rich?
    Feb 2009
    Roanoke, VA
    MAF was just replaced approx 6 months ago (had a surging issue), after market air intake with open filter added approx. a year ago, filter is still clean and good. Plugs and wires were replaced last year at same time of air filter setup......how can I go about checking injectors?
  4. #4 Re: SES for Bank 1 too rich?
    GTP Level Member
    springfield IL
    if it was the injectors wouldnt hear a small tick sound..???
  5. #5 Re: SES for Bank 1 too rich?
    Pennsylvania
    Quote Originally Posted by Brammer View Post
    Lies. Clean your filter. It's dirty.
    And clean your MAF. That's dirty, too.
    Check your spark plugs for condition and gap. If they're coppers, they can start to go bad around 15k miles.
    Anyone know: Does a clogged cat cause you to run lean or rich?
    Oh hey, you didn't tell us any mods except intake filter. Is that all of it?
  6. #6 Re: SES for Bank 1 too rich?
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Clogged cat.. I dont think Ive ever seen a rich or lean situation out of it. Your pre cat sensor determins fuel trim. The only think you would get is a ton of back pressure that would make you run like crap.
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  7. #7 Re: SES for Bank 1 too rich?
    Feb 2009
    Roanoke, VA
    when I bought the car it had some issues where it would not go above 4-5k, was a clogged cat....was replaced then (70k miles, at 116,xxx now). Only mod is the aftermarket intake; However, recently has started doing this surge thing, but only at startup. Sometimes when i start it the RPM's shoot up at start up, then drop to point of almost dying, then picks back up and settles out....
  8. #8 Re: SES for Bank 1 too rich?
    It's not necessarily bank 1 rich (that's P0172)
    here's all I could find on it
    P0148 Fuel Delivery Error
    Found this..but it's very general
    OBDII Code P0148 - Fuel Delivery Error | Engine-Codes.com
    Not sure if it's right at all. I'd want the FSM to see the diagnostic aids. Maybe put a stethescope to each injector/check the wiring to each.
  1. P0172 rich mixture bank one. oxygen sensor?
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2010, 06:49 PM
  2. Running lean in one bank?
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2010, 01:22 PM
  3. Rear Bank Only Misfires
    By pontiackid in forum General Tech Discussion
    Last Post: 06-14-2009, 05:12 AM
  4. UH OH! Here goes my bank account!
    By speedemongtp in forum Off Topic Discussion
    Last Post: 04-05-2009, 10:33 PM
  5. I opened a new bank account
    Last Post: 04-05-2009, 11:05 AM
