Thread: P0171, Vacuum Fitting "T" at TB.
Results 1 to 2 of 2
  1. #1 P0171, Vacuum Fitting "T" at TB.
    SE Level Member KZOO3800's Avatar
    Nov 2010
    Kalamazoo, MI
    My car set a code for the first time ever since I've owned it. P0171.
    1997 Grand Prix SE with 3.8 N/A.
    I have a concerning vacuum leak on the "T Fitting" on one of the vacuum lines that comes from the throttle body. One part of the T goes straight to the transmission. In between the T and Trans there is a reduced diameter fitting. The other side of the T goes (I think) to the fuel pressure reg. All molded fittings related to the T need to be replaced.
    I think the "T" is one of the parts BillBoost posted a picture of here:
    http://www.grandprixforums.net/missi...l36-44921.html
    I'm not sure about the reduced diameter fitting or the one going to the fuel pressure reg. Anyone able to confirm?
    The T is patched up with heat shrunk electrical tape and the reduced diameter fitting is rigged with a straight piece of vacuum hose because the reduced diameter fitting was destroyed. Somewhere between the T and the transmission there is a hissing vacuum leak.
    The OBDII ticket Autozone printed says the following:
    P0171
    Definition: Fuel trim bank one condition.
    Explanation: The powertrain control module uses the oxygen sensor to calculate the Air/Fuel ratio of the engine. The computer has recognized a rich or lean condition on one engine bank only.
    Probable Cause:
    If bank one and two codes set together suspect fuel pressure or MAF sensor.
    Oxygen sensor defective.
    Ignition misfire-repair.
    Fuel injector problem.
    As for observable behavior, the engine seems to misfire mildly on one cylinder when idling. The misfire goes away a few minutes after cold start and doesn't occur at speed. Also, once in about every 100 miles when I'm giving it gas from idle say at a stop light, the engine will seem to just completely die for a split second then keep right on going. Both the misfire and the "sudden death" have been happening since I bought the car.
    Right before the CEL came on I had driven 110 miles on the highway to visit my parents. After the CEL came on I drove 110 miles on the highway to come back home. I make this drive about twice a month without so much as a hiccup.
  2. #2 Re: P0171, Vacuum Fitting "T" at TB.
    Fix all your obvious iisues and see if the code continues. If it continues search on my name with that code and also check me with Lean Bank One.
    I own stock in this code. Own I say.
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  3. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
  4. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
