Thread: 2000 dies for no reason
Results 1 to 7 of 7
  1. #1 2000 dies for no reason
    Jul 2011
    Indiana
    2000 Grand Prix 3.8 natural.
    No problems in the winter. Seems worse with heat. Just driving along, usually slowly, and it dies. However it starts right up again. Hasn't happened yet at road speed. Doesn't happen idling. No codes. He has not noticed the tach dropping to zero but he has noticed sometimes it stumbles a little, but that is a rare occurrence.
    I just read another post that sounded similar and it was the crank positioning sensor. Does that sound like this? Or is there something else I should be looking at also?
    I know the CPS is behind the harmonic balancer. Is that very easy to get off?
    I'm doing this for a friend so I'm not familiar with this car.
  2. #2 Re: 2000 dies for no reason
    Could be the issue. May be something else. It's an easy shotgun to try and fix it though.
    Pull the wheel
    Pop the belts
    Undo the HB bolt (with air it's usually easy)
    3 m6 x 1.00 x ~75mm bolts are needed to pull the balancer. They are not typically in most balancer/wheel puller kits.
    Then it's held on with two 13mm's.
    Reverse and hope for the best.
  3. #3 Re: 2000 dies for no reason
    Troy, Michigan
    hey, I just had this problem and I am dealing with it right now. replaced both the CPS and HB and the stalling seemed to stop but I havent driven it much. Now I have this loud knocking noise, not sure what it is yet. CAREFUL with replacing the HB because I tapped mine in with a hammer and a wrench and i think it ruined the thrust bearing. Instead clean inside where the HB is, lube up the HB, and all I had to do was drive the nut in with the impact wrench and it straight shot drove itself back on. Goodluck
    1999 Grand Prix GT - Red 8000k heads/fogs-flipped doggy bones. Looking for polished GTP wheels from a local in michigan. PM ME!
    l
  4. #4 Re: 2000 dies for no reason
    Jul 2011
    Indiana
    Thanks for the info
  5. #5 Re: 2000 dies for no reason
    That'd be the crank you'd be tapping on.
    Not a good idea.
    Rotate it till it slides on the crank key.
    then push lightly till it seats.
    Then install the bolt and start turning.
    That'll press the balancer back on.
  6. #6 Re: 2000 dies for no reason
    Jul 2011
    Franklin
    I kinda have the same problem I just bought the car and it had a small miss so I put new plugs an wires on it an now it has a worse miss and it is throwin cps code so I guess my ? Is do they just go bad that quick,any help would b apprecated not familier with gtp always drove mustangs thanks for ur time
  7. #7 Re: 2000 dies for no reason
    Its a weak magnet.
    brake dust is magnetic (some) and it rests on the sensor.
    Making the signal even weaker.
    Thus causing issues.
    You could try cleaning it first if you wanted to save money.
    But since most find getting the balancer off a pain, they just replace it while they're there.
  1. 2000 GTP dies!
    By RandalK in forum General Tech Discussion
    Last Post: 02-02-2011, 03:39 PM
  2. 2000 dies while driving?
    By turbostang7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-04-2010, 11:20 AM
  3. 2000 Grand Prix Dies After Continious Running
    By Spk Stephen in forum General Tech Discussion
    Last Post: 03-10-2010, 12:29 AM
  4. 2000 3.8 gp dies
    By redrivergar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-05-2008, 07:07 PM
  5. Main reason for Amp to cut Out
    By jacobmh27 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2008, 09:57 AM
