Thread: stock gt 0-60 slower then normal?
Results 1 to 18 of 18
  1. #1 stock gt 0-60 slower then normal?
    Jul 2011
    Lac La Biche, Alberta
    Hello everybody
    I recently purchased a 2002 Grand Prix GT with 104,000 km (close to 65,000 miles) on it and I was just woundering...
    everywhere I look it seems I should be getting a 0-60 time of about 8 sec but I am getting on average of about 12 sec...what do you guys think?
    Car runs 100% not a stich of problems, shifts great and I wouldn't have thought anything weird about how this car drives or handles except the 4 secound gap in times when I looked up the info before I bought...
    Interested in any opinions
  2. #2 Re: stock gt 0-60 slower then normal?
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Take a 0-60 vid so we can see how it is accelerating.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  3. #3 Re: stock gt 0-60 slower then normal?
    Florida
    Yea that seems verryyy slow considering theres cars with half our power quicker then that. you should be around 8 sec.Something is wrong
  4. #4 Re: stock gt 0-60 slower then normal?
    Grand Island, Nebraska
    Yea they are slow but not that slow.
  5. #5 Re: stock gt 0-60 slower then normal?
    Jul 2011
    Free File Hosting, Free Video Hosting, Online File Hosting. Large Files and Images up to 5GB - YourFileLink.com
    Hopefully that link works, mpg is file format
    car is canadian so in km so just under 100 km = 60 mph in video I take care to 160km/hr (100 mph)
    also gas milage seems good (just under 30 mpg)
    also u may notice cel popped on while doing this video which is wierd first time in 2 months and I drove about 100 miles today wot and fooling around for a good portion with no issues..car is running good still with light...prolly just because it say in that 5-6k range for so long on one shift point
    will get code read asap even though seems wierd it just came on, car perfomance is same as when bought car 2 months ago
    when you click link you will see little green question mark with a counter from 10...then Proceed to File Download Page
    hit that then on bottom of next page you will see Click here to download your file next to another green question mark
    this worked fine for me
  6. #6 Re: stock gt 0-60 slower then normal?
    link no work for me.
    get the code and report back.
    I am kinda thinking clogged cat converter, but it could be something different.
  7. #7 Re: stock gt 0-60 slower then normal?
    Jul 2011
  8. #8 Re: stock gt 0-60 slower then normal?
    Newnan, GA
    First Link did work for me.
    How are you launching it? To get an 8 sec time you have to stomp on the gas like your attacking a man eating spider the size of a dinner plate. Usually your tires will chirp.
    Another thing I noticed is that initially your rpms shoot to 3000, but your speedometer still hasn't budged a bit.
  9. #9 Re: stock gt 0-60 slower then normal?
    Jul 2011
    that was out right stomped, and even though you can't hear in video..with trac control on tires did chirp just gettin hold of my buddy too see if I can borrow his obd2 scanner tonight
    another thing i just thought of is maybe floor mat is holding me up a bit..had a ford aerostar do that..will get code read/cleard and maybe try that
    thanks for any other input in mean time
  10. #10 Re: stock gt 0-60 slower then normal?
    Newnan, GA
    TCS will slow down your car a lot. Launch with it off a couple times and experiment with how hard you stomp to maintain traction. On my old tires I had to back of a hair until 3500 rpm. On my new set I can stomp hard as I can and still only get a chirp.
  11. #11 Re: stock gt 0-60 slower then normal?
    Jul 2011
    so cel went away couple days after, but I was finally able to get the history checked last night...engine misfire :P so I will swap sparky's and maybe wires (wires look fine I will just make sure I dont break any, if I don't I will leave OEM in)...clean MAF sensor as well and hopefully be good to go!
  12. #12 Re: stock gt 0-60 slower then normal?
    Replace the wires.
    They're cheap.
    Get AC Delco 41-101 plugs and any wire set with a lifetime warranty.
  13. #13 Re: stock gt 0-60 slower then normal?
    Jul 2011
    10-4 back door, due to being in a small town change will happen most likley tommorow for parts to get in...but you never know slim chance maybe they got what I need! (no gm dealer)
  14. #14 Re: stock gt 0-60 slower then normal?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    wow that is slow my car with traction controll on will start spinning really good then my traction contriol goes on but i still spin for atleast 2 secs before traction controll kicks in, with traction control.....well i spin alot lol, last time i did stomped on the gas it burned for atleast 5 seconds and i only did that cause i was trying to bust my tranny befoer putting in the new one lol(it was slipping, hard shifting)
  15. #15 Re: stock gt 0-60 slower then normal?
    Jul 2011
    so new plugs and wires on friday, as well as air filter...cleaned msaf and air intake sesor as well...car runs a bit smoother which is to be expected i suppose..but still 12 sec 0-60 and when im hammering down on it expescially in higher rpm I still get a misfire (check engine starts to flash and slight hesitation kinda of bump in acceleration) though light does not stay on now...
    Think next thing I will try is a little 1/4" hole just before my cat converter and see if that helps
  16. #16 Re: stock gt 0-60 slower then normal?
    Newnan, GA
    High Rpm misfire could be caused by a fueling issue. Injectors can keep up at slow speeds, but fall behind at higher speeds maybe? I would suggest running some cleaner like seafoam through, couldn't hurt.
  17. #17 Re: stock gt 0-60 slower then normal?
    Jul 2011
    tried seafoam (1/3 in brake booster line, 1/3 crank case, and last third in gas tank)
    no smoke and doing the same thing still...
    try drilling hole out next i guess
  18. #18 Re: stock gt 0-60 slower then normal?
    Jul 2011
    well definitly hoping it's a plugged cat...just called gm dealer next town over and my car indeed qualifies for free replacment (10yr/120,000 mile)...I will pull front o2 sensor too see if there is abnormal back pressure and then look at getting them car asap...of course I have a 1100km trip to do this weekend first :-/
  1. Is this normal?
    By PurpleGuy in forum Audio, Security & Visual Electronics
    Last Post: 01-13-2011, 08:12 PM
  2. Is this normal?
    By dmahlikGT in forum General Tech Discussion
    Last Post: 01-01-2011, 01:10 PM
  3. Is this normal?
    By Scal24 in forum Visual/Body Modifications
    Last Post: 10-19-2010, 04:55 AM
  4. Car is slower after ZZP HV3 install?
    By DBGP in forum General Tech Discussion
    Last Post: 02-24-2010, 03:11 AM
  5. Is this normal?
    By 2001GTP in forum General Tech Discussion
    Last Post: 01-11-2010, 08:10 AM
