Thread: Power Steering is SCREAMING. HELP A GIRL OUT!
Results 1 to 20 of 25
  1. #1 Power Steering is SCREAMING. HELP A GIRL OUT!
    Hey ya'll I am new to this whole thing, I recently noticed my car screaming and I started thinking maybe its just because its so cold out (sorry I am from MN where it does get rather cold and often cars dont start)
    NEWHO.....
    I drive an 2001, grandprix GT 3.8l V6 and I am 100% positive its the power steering and i am scared to drive it because I am small and cannot control my big baby if it does give out.
    I contacted a few places on repairing it, its not cheap but oh well however I was advised to check a few things first.
    Question.... where is sams heck is the power steering resovore (spell check)??? They said it should be located on the passanger side but I have spent a half hour standing out in the cold trying to find it and I am having no luck!
    PLEASE HELP ME LOCATE THIS DARN THING!!!!!!!!!!!!!
  2. #2 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    GTP Level Member David99GTP's Avatar
    Florida
    On mine its under the Alternator bracket. I wondered where mine was until I had my alternator off and the bracket housing.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  3. #3 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    GT Level Member hester21289's Avatar
    Monroe, GA
    On the GT's Non Supercharged 3.8, the power steering reservoir is right under the Alternator itself. It is very hard to see, the easiest way to do it is to move your coolant reservoir out of the way, and its a little easier to see.
    Hope that helps, mine was doing the same thing, I just filled my reservoir to the correct amount and I havn't had any problems since.
    2004 Chevrolet Impala SS
  4. #4 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    Monroe, GA
    The coolant reservoir is outlined in the yellow, If you didn't know where it was.
    But its held on by two small nuts that are very easy to get off, when its moved out of the way(just pull it towards the front of the car). Look direcly under the alternator and you'll see the cap that says power steering fluid.
  5. #5 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    PA
    Yes, first thing you should do is check the PS fluid. But make sure the car is cold first. If the car is warm, you can end up burning your arm. Not fun. But I have never had to remove the coolant resivour to get to the PS pump. Yes, it is difficult to find, or see. But not hard to just get your hand down in there and remove the cap. Especially with smaller arms than I.
    So check your PS fluid. If it is low, fill it back up. But remember, even if the noise goes away, that fluid leaked out somewhere. Consider getting it looked at to find the leak.
    Also, wanted to ask if you have noticed your steering getting hard at any time? Some do it when hot, some when cold, some only when turning slow. If so, then definitely a problem with the PS. If not, you could have a bad idler pulley, or a bad alternator, or a bad water pump. All those are on the same side of the engine and real close to one another. So sometimes it is hard to locate the one making the noise. So keep an eye out for signs of those going bad.
    2001 GSE
  6. #6 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    Florida
    Quote Originally Posted by Zef_66 View Post
    Yeah, what he said! BTW I had a small leak on my olds one time in one of the lines. So Like ZEF said even if you top it off it leaked somewhere. Keep an eye on it and find the leak so you can get it fixed. You dont want to ruin your pump over a possible hose leaking. Like it was said a little tricky to find. Heck i didnt notice mine until i was tearing parts off for a mod and saw the cap.
    1999 GTP
  7. #7 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    I live here. UR LOSN's Avatar
    Rockford, IL
    check the fluid level.
    does it whine while turning? or just driving in general?
  8. #8 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    SE Level Member AlmightyBirdman's Avatar
    Chicago, IL
    I went through probably 4 power steering pumps in 3 months just because the place I kept going to for my repairs didn't put in a GM pump, but an aftermarket pump. Don't worry, you're car is safe to drive it's just is going to sound like **** and it'll be a little difficult to turn. When my recent one started leaking again about a month ago I put it some of the power steering fluid with the additive to stop leaks. Cost me bout $3 at Advance Auto Parts and now I don't hear any whining at all.
  9. #9 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    Quote Originally Posted by AlmightyBirdman View Post
    x2. I went through two remanufactured pumps with mine. MSRP on a new pump from GM is $172, and you can get them a lot cheaper from GM Parts Cheap - Genuine OEM Online or PACE Performance - GM Parts, Crate Engines, and Aftermarket Accessories. You could also get a low mileage used one from Ed Morad (look up Morad Parts Company on eBay). Don't get screwed like I did (they charged me $220 for the reman pump).
    The good news is, if the fluid's full and it's still whining, you can still drive the car without worrying.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  10. #10 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    Barksdale AFB, LA
    The pump on the 3800 whines. No way around it. I've noticed that if you let it get low once, it'll whine louder the rest of its life but not sacrifice performance. Mind you, the new loudness is nowhere near "I'm out of fluid" loud, but it is definitely a bit more than when the car was new.
    Just about every 3800 I hear accelerate by me while walking has that whine.
    2009 Subaru Impreza WRX STI
  11. #11 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    Apr 2008
    Chillin at the Beach , VA
    Quote Originally Posted by Sabrewings View Post
    I go through that with mine know. Especially when the fluid is cold and thick. Not a loud whine, but enough to hear it. Fluid level is fine, but got the whine. A few miles down the road and it goes away.
  12. #12 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    SE Level Member GAGT+GP-OWNER's Avatar
    May 2008
    DARTMOUTH, NOVA-SCOTIA,CANADA
    mine different year of gp 2007 . but was getting that at 31,501 klms . turns out they sanded off rust on one of the pulleys and change the belt. noise was at satrt upand idle. heard less or maybe not at all when i drove car at higher speeds.
  13. #13 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    May 2008
    i had scretching but after sanding rust off a puuey and new belt. mine is super quite. but mine is a 2007
  14. #14 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    GT Level Member johnnyj773's Avatar
    May 2008
    Chicago(southside)
    yea i noticed it when i first got the car in march.i just psych my self out and pretend its a gtp.lol.man i want one.
  15. #15 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    Apr 2008
    Quote Originally Posted by johnnyj773 View Post
    In due time man, in due time. Be patient, it will be well worth it in the end!!!
  16. #16 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    May 2008
    Chicago(southside)
    Quote Originally Posted by BADAZGTP View Post
    yea one day.hopefully when i finish school i can get something better like a g8,gto, or firebird.say u see that 2011 trans am concept?man that car sick.hope they decide to make em.
  17. #17 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    Apr 2008
    Haven't seen it yet. I'll google it and see what I can find. I'd love to have the GTO. At the Pinks AllOut I went to, a guy had one and upgraded it to a 6.7L. It was pretty quick. And another ran a S/C and was down right rediculous. Low 11's I believe in the 1/4. I like the new G8 Also. Major sleeper. Big HP in a sedan. WOW!!!
  18. #18 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    May 2008
    Chicago(southside)
    yea that g8's nice,just weigh as much as a damn truck.they got a gxp version suppose to do 400+.that'll be the srt8's poison.
  19. #19 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    May 2008
    Chicago(southside)
    lol,i heard that.
  20. #20 Re: Power Steering is SCREAMING. HELP A GIRL OUT!
    May 2011
    Brampton, Ontario, Canada
    Not sure if it'll help or not, but today I found mine!!! I drive an '05 Grand Prix (Base).
    I posted a vid on YouTube so people wouldn't be going nuts like I was. Hey if it helps someone find it, why not?
    ‪2005 Pontiac Grand Prix (Base Model) - Power Steering Reservoir [Where is that damn thing anyways?!]‬‏ - YouTube
  1. Wheelskins leather steering wheel ?
    Last Post: 02-25-2017, 08:20 PM
  2. Power Steering Pump Replacement [*]
    By UR LOSN in forum How To Write-Ups/Tech Tips
    Last Post: 05-11-2013, 03:28 PM
  3. Without power again
    By Rocket468 in forum Off Topic Discussion
    Last Post: 04-21-2011, 12:50 AM
  4. 2005 Power Steering Pump Seems Thrashed
    By Myoldmopar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-12-2009, 07:28 PM
  5. power steering
    By Toasty in forum General Tech Discussion
    Last Post: 02-23-2008, 01:24 PM
