Thread: Oil pump issues?
Results 1 to 4 of 4
  1. #1 Oil pump issues?
    Newfoundland
    I bought a 2001 impala, 3800. The owner said that thre is a tick/ knock due to no oil getting up around the valve train, he said the oil pump is bad. I'm just wondering if you guys think it's the same issue or something else
    Any help is appreciated as alway.
    Kyle.
  2. #2 Re: Oil pump issues?
    its very, very hard to break the oil pump since it's driven off the crank.
  3. #3 Re: Oil pump issues?
    PA
    Yeah, probably not an issue with the oil pump. Very unlikely.
    I would hook up an oil pressure gauge to make sure. But probably more of an issue with coolant getting into the engine and spinning a bearing.
    2001 GSE
  4. #4 Re: Oil pump issues?
    Newfoundland
    So it turned out it wasn't that at all, a lifter collapsed and caused a racket. There's no damage done. I'm not sure if you can buy these individually , and I know 3400 uses the roller litters. Will one from a 3.4 work?
  1. fuel pump issues
    By jspangler22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2011, 02:50 PM
  2. Having issues with HVAC Fan, AC PUMP, ECT.
    By rynoman03 in forum General Tech Discussion
    Last Post: 03-21-2011, 01:39 AM
  3. 97 GTP Idleing issues or fuel pump? Help if you can.
    By h0wl0ngcanitbe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2011, 01:14 PM
  4. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  5. oil pump??
    By a.caldwell11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2008, 02:07 AM
