I can't scan KR. I have 7mm Duralast plug wires and I'm using E3 Plugs
Fixed my problem. It was getting false knock. I had the car on the lift to do control arm bushings and noticed a wire resting on the axle. Followed the wire and it went to the knock sensor on the back side of the engine. The axle worn through the plastic down to the copper wire inside. I fixed the wire and put it up out of the way. Car has the power it used to again
I noticed a little better fuel mileage after I put the E3 plugs in. Thats what they advertise but it wasn't a significant amount but noticable
