http://www.grandprixforums.net/power_steering_pump.php
what this write dont tell you is there is a clip on the back side of the pump that holds a wire and its clip, after you un bolt it look behind on the bottom back side for the clip, i removed my pump through the wheel well, it wouldn't fit coming through the top side. the new pump should have a pulley puller with it, its a bolt and nut, and should have instructions how to use it. if not then a good power steering pulley removal tool is 30 bucks and make the job easy.
heres how to vid to use the nut and bolt puller YouTube - ‪How to replace Power Steering Pulley‬‏
this is the puller i have, minus the nice box Power Steering Pulley Puller/Installer | AutoZone.com
