Thread: overheating
Results 1 to 15 of 15
  1. #1 overheating
    SE Level Member zach_gt's Avatar
    May 2008
    my car overheats everyday i just replaced the warter pump that fixed it for awhile and now it started overheatin again and it looks like i am losing water but idont no where i have to put water in it every day could it be boiling the water and evpaorting it
  2. #2 Re: overheating
    Saraland Alabama
    check the oil, it could be a head gasket, you could also have cracked the plastic elbow at the water pump to intake. If it is evaporating the system isn't pressurized
  3. #3 Re: overheating
    May 2008
    ok ill check that nope no water in oil
  4. #4 Re: overheating
    PA
    Did you bleed the coolant system properly after you changed the water pump?
    2001 GSE
  5. #5 Re: overheating
    Bastard Reptile's Avatar
    Kansas City, MO
    How hot is it getting?
    Like Zef said, did you bleed the coolant system to get all the air out of it? If you have an air bubble in the thermostat housing, it will not operate properly.
    Have you tried replacing the thermostat? for what they cost you may want to look into this.
    OR
    does it only heat up in traffic or does it get hot on the highway also.
  6. #6 Re: overheating
    May 2008
    i found the problem it is the hose that goes to the belt tensior to the intake was cracked
  7. #7 Re: overheating
    Barksdale AFB, LA
    Quote Originally Posted by zach_gt View Post
    It's a plastic coolant elbow, and there are two of them.
    2009 Subaru Impreza WRX STI
  8. #8 Re: overheating
    May 2008
    wheres the other one i can only find one and do i have to replace the tensior or intake
  9. #9 Re: overheating
    Barksdale AFB, LA
    The other elbow is further down the tensioner and goes into the block. You can remove the tensioner by removing the bolts and pulling straight towards the passenger side of the car. Installation is the reverse of removal.
  10. #10 Re: overheating
    TDCRacing
    Guest
    Buy two of them. you can get them in the help section of any auto parts store. The other one will crack on you when you take it out. Also sometimes half of the elbow cracks in the housing so make sure you get it all out before putting the new one in.
  11. #11 Re: overheating
    Barksdale AFB, LA
    Quote Originally Posted by TDCRacing View Post
    Am I the only one who didn't damage the original elbows when removing the tensioner? Doing my gaskets both original elbows were still usable but I went ahead and replaced them with the ones I had bought.
  12. #12 Re: overheating
    TDCRacing
    Guest
    Quote Originally Posted by Sabrewings View Post
    LOL looks like you were a little bit too carfull...wich is a good thing when it comes to working on cars i guess. Mine was actually seized in what is it the lim and the bracket? anyway they boke on each side right on the edge of where they exited each peice. so i had to dig them out.
  13. #13 Re: overheating
    Mine were fine too, but again I went ahead and replaced them anyways
  14. #14 Re: overheating
    PA
    FWIW, my 97 GTP only has one plastic elbow.
    2001 GSE
  15. #15 Re: overheating
    Saraland Alabama
    Quote Originally Posted by Zef_66 View Post
    mine too, although it is modified
  1. HELP!! overheating
    By sciontc1011 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:55 PM
