Thread: top swap with just intakes.
Results 1 to 3 of 3
  1. #1 top swap with just intakes.
    Newfoundland
    I just found a 2000 Bonneville, for a very good price, If not free, Its a 3800 n/a But the plastic upper intake is destroyed. It blew up appartenly. could i just take the blower and lower intakes off my l67 and bolt it on this motor?
    Or could i just drop the l67 into the bonneville?
  2. #2 Re: top swap with just intakes.
    Charles City, IA
    Read the top swap thread.
    SMGPFC Two Nipple General
  3. #3 Re: top swap with just intakes.
    Florida Tuner Z34Phoenix's Avatar
    Florida
    the SC wont fit on an NA lower intake manifold. and to use the lower intake from the L67 you need the heads as the fuel injectors spray into the heads vs the lower on the l36. ZZP has a m90 kit for the l36 where they have holes in a modified lower intake for the injectors. but this requires new fuel rails that are pricey and you have to use their pulleys as you are just using one belt vs 2 for the l67
    96 Z34 (RIP LQ1 14.81@92.3) L36 Swap 14.9@91.5 www.cardomain.com/id/z34phoenix
    Topswap: P&P All,Si Valves,L76's,LW Pushrods,SD's,DHP PT PB 13.91@99.8
  1. Air intakes
    By NewGPkid in forum 04+ Specifics
    Last Post: 10-19-2010, 04:23 PM
  2. which is better on intakes?
    By a98gtp4u in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2009, 08:43 AM
  3. intakes
    By MakeitLouder97 in forum General Tech Discussion
    Last Post: 07-25-2009, 11:43 AM
  4. intakes
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2009, 10:31 PM
