Get a pressure tester and see if there are leaks in the line. Apparently the places your taking it aren't that special if they can't figure out a simple A/C system. It's common sense really...if it didn't work...you added freon...and then it worked for a bit...then it doesn't work again after it had time to bleed out...then there is a leak. Find it and have it fixed.
