Thread: ZZP flex pipe
Results 1 to 4 of 4
  1. #1 ZZP flex pipe
    GTP Level Member apierce1289's Avatar
    United States
    Ok so i have SD headers and bought a 3" flex pipe from zzp so i wont get leaks and noises from it. The guy at the shop said he lined it up as close as he could to the original
    My big question is if its not lined up perfect just like the other will i have a big issue?
  2. #2 Re: ZZP flex pipe
    Probably not. It all depends on how "close" he closely lined it up. I had a flex replaced by eye and it came out fine.
    How soon you installing?
  3. #3 Re: ZZP flex pipe
    United States
    within a month and i need to set up the appointment with you do you have the tools if he didnt line it up good?
  4. #4 Re: ZZP flex pipe
    I have a sawzall and a welder. Admittedly, my welds don't come out looking like I weld every day, but I can hold two pieces of metal together and stop leaks from leaking. Not long ago I did three installs in one week. The last needed an adapter, except you can't buy a 3" to 2.25" on the spur of the moment and have it work properly. Had to weld a couple of adapters together and make it all work etc. Without trying to inflate my own ego, I'll say.. I've worked my way out of a bunch of hopeless looking situations in the past.
    Hit me up before you need it done and I'll get you on the schedule. But I'll probably need to schedule it. Between other folks and a girlfriend who's living with me, I gotta make sure I have things scheduled. Nearly gotta schedule bathroom breaks ....lol
  1. Has anyone ordered a zzp flex pipe lately?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 06-25-2010, 02:43 PM
  2. Flex plates.
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 04-12-2010, 09:35 PM
  3. 06 gp frame flex??
    By reallyfast1 in forum 04+ Specifics
    Last Post: 09-12-2009, 09:18 PM
  4. Flex Pipe
    By ARFF22 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2009, 09:59 PM
  5. noisy flex
    Last Post: 04-11-2009, 01:22 AM
