Thread: dtc's from hell
Results 1 to 5 of 5
  1. #1 dtc's from hell
    Apr 2009
    freehold,ny
    i replaced my upper and lower inatke gaskets earlier today and drove it around and it was fine i just headed out to get cigs. and p0102 maf low voltage,p0118 engine coolant voltage high, p0131 ho2s bank 1 low voltage, p0202 injector 2, p0204 injector 4, p0205 injector 5, p0206 injector 6, p3233 unknown can't find any data on this code, simple question "what the f**k is going on with my car"
  2. #2 Re: dtc's from hell
    St. Louis
    Did you miss any electrical connections after getting everything back together? I'd go back over the entire harness and make sure everything is where is belongs.
  3. #3 Re: dtc's from hell
    Major ground issue would be my first thought.
  4. #4 Re: dtc's from hell
    wow..i think i would just walk away from that one and come back to it later
    sounds like thats going to be a major PITA
    SMGPFC Member #10
  5. #5 Re: dtc's from hell
    utah
    second on the ground issue. might have sliced a wire during install or removal
  1. Hell on wheels
    Last Post: 12-12-2010, 09:52 PM
  2. what the hell is this? pics..
    By NaturallySmashed in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-04-2010, 03:12 PM
  3. What the hell just happend
    By Freebeer187 in forum Off Topic Discussion
    Last Post: 12-10-2008, 08:24 PM
  4. What the hell is wrong with me....
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 09-14-2008, 04:27 PM
  5. Where the hell did this car go?
    Last Post: 09-09-2008, 09:30 AM
