Thread: Water pump leak, or not?
Results 1 to 20 of 22
  1. #1 Re: Water pump leak, or not?
    i've never put one in but from what i've read , i think you put it in the alt bracket and line the elbow up with the manifold and wiggle it as you tighten it down, to get it to go in and seal properly. and a little spit for lube on the O rings lol
  2. #2 Re: Water pump leak, or not?
    Bellevue, Neb. Close to Omaha
    That's what I did Scotty thanks. It went together fine, I think. I put a light bead of silicone on the outer edges of the elbows.
    But get this. My car doesn't have a belt routing decal and I'm trying to figure out how to put the damn fan belt back on.
    I'll see if I can find it online.
  3. #3 Re: Water pump leak, or not?
    It's all back together. It wasn't a problem putting the elbows on the tensioner bracket and installing it.
    Now I should flush it and replace that Dex Cool crap with some regular anti freeze. Peak makes an antifreeze that works with any kind. I also had another thermostat that was stuck open. It was replaced in November when I replaced the Dex Cool.
    Again, I really appreciate everybodys input on this thread.
  1. Massive water leak
    By hahaha38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2010, 07:19 PM
  2. '04 GP GTP Water Leak (Different)
    By Jadentsu in forum General Tech Discussion
    Last Post: 06-23-2010, 12:22 AM
  3. Water Leak......need help....THX
    By jas98gtp in forum 04+ Specifics
    Last Post: 05-16-2010, 11:04 AM
  4. water pump housing leak??
    By 16MustangVet in forum General Tech Discussion
    Last Post: 02-08-2010, 12:06 PM
  5. trunk water leak
    By abweiss in forum General Tech Discussion
    Last Post: 11-25-2009, 08:28 AM
