Thread: Cooling fans not funtioning
Results 1 to 16 of 16
  1. #1 Cooling fans not funtioning
    NE
    Hi everyone,
    I have a 1997 pontiac grand prix with a 3.8 engine. I have noticed that the cooling fans do not turn on. I have checked fuses, relays, replaced the temp sensor by the thermostat. I have also put 12v power to the fans and they both run. I don't know where to go from here, I do know that only one of the four wires going to the fans checks out to a ground, not sure if the other three are all power wires ro if i have a bad ground there.
    Thanks
  2. #2 Re: Cooling fans not funtioning
    You sure the motor is even getting hot enough to run them.
    The fan speeds are 214º ans 226º IIRC.
    Turn your AC on and see if one of the fans turns on.
  3. #3 Re: Cooling fans not funtioning
    NE
    I had it up to 250 according to the temp gauge last night and still nothing. I also noticed that when I turn the a/c the cooling fans do not turn on either.
  4. #4 Re: Cooling fans not funtioning
    Apr 2009
    Fort Worth TX
    Check relays?
  5. #5 Re: Cooling fans not funtioning
    NE
    Relays are good as well as fuses.
  6. #6 Re: Cooling fans not funtioning
    Apr 2009
    Fort Worth TX
    I'm trying to get the schematic, hold on.
  7. #7 Re: Cooling fans not funtioning
    Apr 2009
    Fort Worth TX
    Here is the chassis schematic
  8. #8 Re: Cooling fans not funtioning
    Apr 2009
    Fort Worth TX
    The first thing I would do is trip the relays with the low voltage control and see if fans come on. That will tell if everything is good from relay to fan. If fans do come on, then you probably don't have a control signal to the relay from the PCM. The schematics will make it a little easier; gives you wire color.
    Control wires from the PCM out to relays are dark green for fan 1 (right) and dark blue for fan 2 (left). Take note of the chassis shcematic as there are three relays.
  9. #9 Re: Cooling fans not funtioning
    NE
    So i went to the parts store tonight to use their code reader. Come to find out that when the gauge on the car reads almost 250 the computer only reads about 225 and both fans turn on at that point. Is there any way to recalibrate the temp gauge or would it be easier to put in an after market temp gauge to be more accurate?
  10. #10 Re: Cooling fans not funtioning
    Apr 2009
    Fort Worth TX
    This doesn't make any sense. You said fans do not come on when AC is on. Either the PCM is bad or the AC pressure switch is bad.
    Yes, you can change fan settings on the PCM. It requires a re-flash. Could it just be a bad temperature sensor?
  11. #11 Re: Cooling fans not funtioning
    NE
    I don't understand it either. I know that I need to recharge my a/c because it has a leak in it somewhere. Maybe there isn't enough pressure with a/c on to turn the fans on. Not sure just throwing that out there. Is it possible to recallibrate the temp gauge in the dash so it is more accurate?
  12. #12 Re: Cooling fans not funtioning
    if your a/c is not working, as in the clutch is not spinning on the compressor, the fans will not be coming on.
  13. #13 Re: Cooling fans not funtioning
    Apr 2009
    Fort Worth TX
    Good point. I was assuming that the clutch was coming on.
  14. #14 Re: Cooling fans not funtioning
    NE
    So I recharged my A/C tonight and as I was charging it the fans turned on as the should as soon as the a/c compressor clutch started up. So all is well. Thanks for the help!!!
  15. #15 Re: Cooling fans not funtioning
    Apr 2009
    Fort Worth TX
    Good to hear.
  16. #16 Re: Cooling fans not funtioning
    When the climate control sends the request for AC. it's only a request. If the pcm knows it's not turning the AC compressor on then the fans are also not commanded to come on.
  1. cooling fans on 90 G.P.
    By TIMS TURBO in forum General Tech Discussion
    Last Post: 05-01-2012, 06:34 AM
  2. cooling fans always run
    By jaxso6 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2011, 08:33 PM
  3. 1994 no cooling fans
    By redtrucks in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-10-2011, 07:31 PM
  4. Cooling fans only work with ac
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2009, 08:54 AM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
