Thread: turns over fires back fires then wont start
Results 1 to 7 of 7
  1. #1 turns over fires back fires then wont start
    Apr 2011
    georgia
    i am currently looking at a 2000 grand prix GT1 3.8L for 300 bucks it wont start it turns over fires then back fires. anyone have a idea whats wrong
  2. #2 Re: turns over fires back fires then wont start
    Charles City, IA
    Any more info? Did it just start doing this or did it have prior issues also?
    SMGPFC Two Nipple General
  3. #3 Re: turns over fires back fires then wont start
    Jan 2009
    Tallahassee, FL
    Codes? Fuel pressure?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  4. #4 Re: turns over fires back fires then wont start
    Apr 2011
    georgia
    i have no idea i havent ven seen the car yet.i just know it back fires and wont start my Grand am dose that if i let it sit to long. but if i let it sit a hour or 2 after i try to start it will start right up. but thats a 2.4l GA i dont really wanna waste 300 bucks on this GP if its not worth buying
  5. #5 Re: turns over fires back fires then wont start
    St. Louis
    Unplug the MAF and see if it starts.
  6. #6 Re: turns over fires back fires then wont start
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Sounds like a timing issue. Hell for that much I would buy it and just swap another engine in it if the body is in good shape.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  7. #7 Re: turns over fires back fires then wont start
    Banned
    Apr 2011
    wv
    check all 6 plug wires and make sure theyre connected to the right cylinders. then check all 6 injectors and make sure each one is firing
  1. Could THIS Be Causing All of the Engine Fires?
    By SuperSport in forum General Tech Discussion
    Last Post: 04-27-2017, 06:40 PM
  2. Intermittent stalling on startup, then fires right up on second try. Ideas?
    By ChvyTrcksFrdScks in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2010, 06:17 PM
  3. 00 GT wont start but turns over
    By dwagn313 in forum Introductions/Noob Questions
    Last Post: 06-18-2010, 06:30 PM
  4. Heavy stutter under boost, but no mis-fires
    By 007 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2010, 12:46 AM
  5. 97 fires but wont run.
    By clh97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-20-2009, 10:08 PM
