Thread: Engine problems
Results 1 to 7 of 7
  1. #1 Engine problems
    SE Level Member kenizzle36's Avatar
    Apr 2011
    Menasha, Wisconsin
    For some reason my car is getting warmer than usual. Gets up to 210. Then when I come to a stop sign or lights the car will keep trying to move forward on me. Also when I take off it sounds like its miss firing. Any ideas on what that is?
  2. #2 Re: Engine problems
    It's warming up, your idle is probably coming up from the AC being on etc.
    As for the car being 210, the fans don't come on until 216F/228F, if you sit in traffic, that's normal.
    Is the car pulling hard at the stoplights? Maybe the TPS is going bad and it's reading that you are still lightly on the throttle etc. All these are possible.
    Any more detail around how it's behaving etc?
  3. #3 Re: Engine problems
    Apr 2011
    Menasha, Wisconsin
    Well it only does it once every couple days. I get pissed easily and when I take off ill floor it. Then the temp comes down and the car is fine.
  4. #4 Re: Engine problems
  5. #5 Re: Engine problems
    Apr 2011
    Menasha, Wisconsin
    Seems to work like a charm.... just dont want that to be the fix for it. A friend of mine said maybe the head or heads are warped... could that be the issue?
  6. #6 Re: Engine problems
    St. Louis
    No, not likely.
    Sounds like the temps are normal and the TB could use a good cleaning.
    When was the last time you had a tune-up?? Changed the fuel filter?
  7. #7 Re: Engine problems
    Apr 2011
    Menasha, Wisconsin
    Just did the plugs and wires like 2 weeks ago. Fuel filter Im not sure. Only owned the car for about 2 months now.
  1. 2004 Engine Problems - help!
    By davepond88 in forum Introductions/Noob Questions
    Last Post: 07-23-2010, 04:34 PM
  2. Engine swap done, problems
    By atruebudfan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2009, 01:48 AM
  3. could a top swap on my n/a 3.8 v6 engine fix current problems?
    By GEMINIokc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2009, 08:59 AM
  4. Intermittent Engine Stalling Problems
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-16-2008, 07:59 AM
  5. Problems Starting after Engine Replacement.
    By Metallistar in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2008, 07:54 PM
