Thread: High pitched hum and vibrating sounds?
Results 1 to 10 of 10
  1. #1 High pitched hum and vibrating sounds?
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    So just within the past couple days my GP has been making some weird sounds. It started with a high pitched hum, then the hum with a louder vibrating sound. I've checked the belts but they seem to be ok and were replaced last summer. Everything still feels normal too. It's also completely stock not even an intake or anything. Any ideas would be appreciated!
  2. #2 Re: High pitched hum and vibrating sounds?
    St. Louis
    When does this occur? In park idling? While driving? All the time regardless? Specific RPM range? Gotta give us some specifics. What year is the car?
    Check your power steering fluid. The pump can whine when it gets low on fluid.
  3. #3 Re: High pitched hum and vibrating sounds?
    Buffalo, NY
    Thanks I will check that and it's a 98 and the sound happens all the time.
  4. #4 Re: High pitched hum and vibrating sounds?
    Jan 1970
    Maquoketa, Iowa
    Sounds like somebody hard wired a vibrator in your glovebox... Lol
  5. #5 Re: High pitched hum and vibrating sounds?
    St. Louis
    Quote Originally Posted by FoSHO99 View Post
    No need to be a "d*ck" about it, lol.... Sorry, couldn't resist
    Do you hear the hum when you have the blower on? Might be the blower motor causing the vibration/hum sound. When they get junk in the squirrel cage or the motor starts to go bad they can be out of balance and the higher the fan speed, the worse it gets.
    Also I forgot to ask, is your CEL on?
  6. #6 Re: High pitched hum and vibrating sounds?
    Buffalo, NY
    haha I wish there was a vibrator in my glovebox atleast that'd be an easy fix.
    And the noise is there all the time whether the blowers on or off and no CEL.
    It became to dark too fast so I was never able to check the power steering fluid but that will be the first thing I do tomorrow.
  7. #7 Re: High pitched hum and vibrating sounds?
    Houston
    Id put a Ratchet extension on your alternator and listen to see if its coming from there. Mine did the same thing and thats what it was.
  8. #8 Re: High pitched hum and vibrating sounds?
    Reynosa,Mexico
    Mine does the same thing its a 99 GP GT also all stock already changed tensioner pully bearing, and water pump thinking it was that also checked power steering fluid and thats not it the noise my car makes it also high pitched, I'm thinking on changing the A/C compressor since thats not working thats posibly it in my case cuase I took the belt off and gave the comp. pully a few turns and sounds like bearing is messed up.
  9. #9 Re: High pitched hum and vibrating sounds?
    Reynosa,Mexico
    also almost forgot any body know if you can change out the power steering pump pully ball bearing or do youy have to change out the whole thing?
  10. #10 Re: High pitched hum and vibrating sounds?
    Quote Originally Posted by Corona99GT View Post
    you will need to replace the whole pump.
  1. High pitched whine
    By penguinknot in forum Brakes/Suspension/Chassis
    Last Post: 02-23-2011, 07:34 PM
  2. High Pitched squeal after pads and rotors
    By SuperSport in forum Brakes/Suspension/Chassis
    Last Post: 09-27-2010, 11:45 PM
  3. High pitched noise coming from dash?
    By Gortox454 in forum General Tech Discussion
    Last Post: 08-14-2010, 08:48 AM
  4. high pitched whine??
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2010, 03:37 PM
  5. high-pitched whistle and bouncing idle
    By CSteen85 in forum General Tech Discussion
    Last Post: 04-28-2010, 07:58 AM
