Thread: grounds
Results 1 to 4 of 4
  1. #1 grounds
    SE Level Member ewok's Avatar
    Shelbyville
    I have a 98 gt coupe 3800 and I'm getting a p0107 and also my gas gauge and coolant temp gauge is off along with an intermittent srs light which leads me to believe I'm having a ground issuse.
    Question is where would I find said grounds?
  2. #2 Re: grounds
    Omaha, NE
    Sounds morel like a vac leak to me. That code is for a MAP sensor.
  3. #3 Re: grounds
    Shelbyville
    I pulled the code at work cleared it and it was back before I even fired the engine is what led me to believe that it could possibly be a ground causing the low voltage code....
    that being said I'm a body and frame tech by trade no a driveability tech so I appreciate any input. I will pull the cover and check my vac lines and see where it leads me.
  4. #4 Re: grounds
    Shelbyville
    Well I cleaned the grounds fixed a vacuum leak that I found and cleared the code BUT after driving awhile I parked it for an hour or so and as soon as I fired it the SES was back on and I pulled 2 codes this time a P0107 and IIRC P1107 a low input and intermittent low voltage code. I checked the voltage at the sensor about a half dozen times after that and it was within tolerance around 4.98 volts each time any other ideas and what are the chances the sensor it's self is bad?
  1. Bad Grounds
    By ionroller in forum 04+ Specifics
    Last Post: 12-15-2009, 08:53 AM
