Thread: 97 grand prix engine swap
Results 1 to 20 of 32
  1. #1 Re: 97 grand prix engine swap
    SE Level Member biscuit's Avatar
    Mt Vernon, MO
    I put the engine n a GT
  2. #2 Re: 97 grand prix engine swap
    SE Level Member curtcamaro's Avatar
    Pella, Iowa, United States
    How the hell do you get to that one bolt on the bell housing that that is facing the opposite direction as the rest?
    I have the passenger wheel off, car jacked up and power steering pump up and out. I have to wait to go get a new elbow socket after i broke my one impact rated one (go figure) to get the exhaust the rest of the way off.
    But my main problem is I can't even see it! i have 3ft worth of extensions to reach it, but I can't see it to line up on it
  3. #3 Re: 97 grand prix engine swap
    GT Level Member Tea Time's Avatar
    New Brunswick
    Theres a black metal bracket on the end of the transmission closest to the pass side wheel, i think its only 4 bolts holding it on, once u remove that bracket, u should be able to see right in there to that bolt unless ur engine (and cradle) are considerably lower on the driver side than the pass side. just look straight in from the pass side but have the engine / tranny level.
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  4. #4 Re: 97 grand prix engine swap
    New Brunswick
    http://www.grandprixforums.net/how-r...ion-35485.html
    This how - to will show u where the bolt u need to get to is...and the bracket u need to remove.
    '97 GTP - Project
  5. #5 Re: 97 grand prix engine swap
    Mt Vernon, MO
    I pulled my engine and tranny both out together and split them, so all I did was use a few extensions.
  6. #6 Re: 97 grand prix engine swap
    One motor out, other motor in, I had to take a break and go work to work till 5, then back out to finish bolting together. TOnight/tomorrow attempt to start it.
    bull **** bolt was easier once we had that bracket out and then rocked the motor/transmission backwards. It had the power steering pump slightly wedged behind the motor in order to hold it out of the way, making it impossibly difficult to see the bolt.
  7. #7 Re: 97 grand prix engine swap
    New Brunswick
    excellent...let us know how u makeout...
    '97 GTP - Project
  8. #8 Re: 97 grand prix engine swap
    I'm so happy right now....Its running....its running well....I'm so happy.
    Buddy who was helping cross threaded a lug nut so need a new stud and lug nut before i'll go down the road. But its running. :-)
    97 GT $500
    Put a motor in and repainted.....now spent $800 more.
    Not bad for a $1300 car.
  1. 1998 Grand PRix GT engine swap
    By 98 Grand Prix Gt in forum General Tech Discussion
    Last Post: 01-19-2011, 11:46 PM
  2. Will a 04 grand prix 3800 engine fit into a 01 grand prix
    By jordan61488 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-24-2010, 01:01 AM
  3. top swap for grand prix gt
    By gtp99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2010, 07:37 AM
  4. 1997 Pontiac Grand Prix to Supercharged engine swap
    By 1997GSX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-28-2010, 08:00 AM
  5. 1998 Grand Prix GT engine swap
    By aandbclark in forum General Tech Discussion
    Last Post: 12-03-2009, 08:04 PM
