Thread: 97 grand prix engine swap
Results 1 to 20 of 32
  1. #1 97 grand prix engine swap
    SE Level Member biscuit's Avatar
    Mt Vernon, MO
    I have a 97 3.8L grand prix, will an engine out of a 99 fit and is there anything that I need to get off of the 99 to make it work in my 97? Thanks ahead of time for any information
  2. #2 Re: 97 grand prix engine swap
    same motor. the throttle body is different, but they are interchangeable.
  3. #3 Re: 97 grand prix engine swap
    SE Level Member curtcamaro's Avatar
    Pella, Iowa, United States
    Hey biscuit I'm doing the exact same thing...only my 97 GPGT car is getting a 99 regal motor, also the same, but post any useful info that you come up with it when you do it. Otherwise I'll do the same when I do.
  4. #4 Re: 97 grand prix engine swap
    Mt Vernon, MO
    You got it, I let you know any snags I have. I pulled the old engine out last night and like the post below states the only difference is the alternator bracket.
  5. #5 Re: 97 grand prix engine swap
    The base motors are identical in all the 3800's 97+. Swap a few accessories/brackets, rear exhaust manifold and flex plate. Those are about he only things to consider.
    Reason I say flex is the H/C/G bodies had a 258mm converter not the 245mm.
  6. #6 Re: 97 grand prix engine swap
    Mt Vernon, MO
    I mounted the transmission on the 99 motor last night and everything bolted up fine. What do you mean by 258 mm and 245mm, will I have shifting problems?
  7. #7 Re: 97 grand prix engine swap
    Mt Vernon, MO
    The only things that I switched over from the 99 motor to the 97 motor was the coil mount (because it is integrated into my top engine mount), alternator bracket (because my new engine didnt come with an alternator and they 97 wont fit on the 99 bracket), and the throttle body. I just finished last night and drove it about 10 minutes ago and it is running like a champ. Feel free to ask any questions and I will do my best to help out in anyway I can.
  8. #8 Re: 97 grand prix engine swap
    I'm starting this week so I'll make sure to ask if I come across any problems
  9. #9 Re: 97 grand prix engine swap
    GT Level Member Tea Time's Avatar
    New Brunswick
    biscuit.....u do the swap into a 97 gt or gtp?
  10. #10 Re: 97 grand prix engine swap
    Plattsburgh,NY
    Make sure you have the alternator from the 99 97 mounts different
  11. #11 Re: 97 grand prix engine swap
    Mt Vernon, MO
    I just ran out to my shop to look, and dang it you were right! What do you think was the only thing that did not come with the motor...... the alternator. It looks like I can switch the bracket over. Do you know if that is possible?
  12. #12 Re: 97 grand prix engine swap
    Grabbed pics to explain it better. The flex on an H/C/G body car has a larger bolt pattern for a larger torque converter. The 04+ cars came with dual drilled flex plates to solve this issue. Meanwhile the pattern on a W body is 245mm and the pattern on these others is 258mm. All this means is the bolts won't line up if you mix them.
    258mm flex with 245mm torque converter looks like this.
    Here's when i pulled it apart and put the right flex on it. See where the bolts are, that's the spacing.
    This customer didn't mention he was supplying an H/C/G motor and 245mm TC. I noted it.
    Here is how it looks when it lines up.
  13. #13 Re: 97 grand prix engine swap
    Mt Vernon, MO
    thanks for the info, very helpful
  14. #14 Re: 97 grand prix engine swap
    THANK YOU, that was the little bit of information I was missing.
  15. #15 Re: 97 grand prix engine swap
  16. #16 Re: 97 grand prix engine swap
    First off, Not sure, some idiot that WAS helping on my car, he has now been demoted to armor-all duty.
    2ndly I'm stuck. Alternator checks out good at o reilly's but the battery light still comes on and drains my battery when running/or not within the time span of half an hour.... HELP?!
    3rd
    There is a hole in the bottom side of the rubber hose running from the air filter box to the throttle body? I'm guessing some kind of drain plug that I am missing for some reason...I don't see anything that could plug in there. Anyone know what it is that I'm talking about?
    97 GT $500
    Put a motor in and repainted.....now spent $800 more.
    Not bad for a $1300 car.
  17. #17 Re: 97 grand prix engine swap
    Don't put amour all on your car... it's crap.
    And if you ever need to know how to best get a part out/off etc. Just ask. PS pump gets hung from the hood strut, remove the diff to engine bracket and the backwards bolt is a straight shot.
    If someone forgets his lug nut super duper security lock then pull the ps pump and lower it.. using one 12-14" extension under the rear exhaust manifold you can do the backwards bolt and take the motor out w/o ever taking off a tire. Right Swiggles?
    LOL BTW security lugs don't deter thieves..they only stop the owner from getting wheels off.
  18. #18 Re: 97 grand prix engine swap
    New Brunswick
    is the battery any good Curt?
    and the hole on the underside of ur air breather tube is supposed to be there and im pretty sure that style of airbox is exclusive to 97 (i think it may be some 98's as well) but there is a piece that goes in there....just a black plastic piece....im not even sure it has a function....i've got a 97 in my yard n as soon as i can get a pic of the piece, i'll post it for ya (just a pocket part from a junkyard).
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  19. #19 Re: 97 grand prix engine swap
    I had a short, MAF sensor was shorting, replaced it and all of a sudden everything was fine.
    Stud replaced, car runs great drives great and shoots off line faster than my old Grand Prix ever did.
    Thanks a bunch for all the help you all have been. One more grandprix owner/lover is now back on the road. Just in time to take my gf to her senior prom tomorrow night. See you all in CHarles CIty/Cedar Falls in May!
    97 GT $500
  20. #20 Re: 97 grand prix engine swap
    New Brunswick
    make sure u get that hole on the underside of the breather tube plugged so ur not sucking in debris....
    '97 GTP - Project
  1. 1998 Grand PRix GT engine swap
    By 98 Grand Prix Gt in forum General Tech Discussion
    Last Post: 01-19-2011, 11:46 PM
  2. Will a 04 grand prix 3800 engine fit into a 01 grand prix
    By jordan61488 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-24-2010, 01:01 AM
  3. top swap for grand prix gt
    By gtp99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2010, 07:37 AM
  4. 1997 Pontiac Grand Prix to Supercharged engine swap
    By 1997GSX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-28-2010, 08:00 AM
  5. 1998 Grand Prix GT engine swap
    By aandbclark in forum General Tech Discussion
    Last Post: 12-03-2009, 08:04 PM
