Thread: Motor Done!!!
Results 1 to 8 of 8
  1. #1 Motor Done!!!
    SE Level Member Sl33p3rGt's Avatar
    Dec 2010
    Modesto
    Yup sux...was at in-n-out lastnight at a car meet..car was running fine
    went to leave out of the parking lot smash it and it stalled out at the light
    tried to start it back up car would barely turn over,finally started and was miss
    firing horribly gotcut it off and coasted into the parking and noticed some
    antifreeze coming out the tail pipe checked oil seemed looked ok hoping a
    a blown head gasket? Could see the rear head had some moisture at the #6 cylinder
    havent pullled anything apart yet or checked plugs....cars at 155,000 miles so im hoping just a gasket kit and not a cracked head
  2. #2 Re: Motor Done!!!
    get the heads checked by a machine shop.
  3. #3 Re: Motor Done!!!
    Pull your UIM, look at it in the area where the EGR tube is..
    Rockauto sells them cheap. Your LIM will contain around 1/2 a gallon of coolant. Don't pull the heads if the lim is full and don't try to start it with the plugs in it.. it should hydrolock soon.
  4. #4 Re: Motor Done!!!
    Dec 2010
    Modesto
    Yeah it hasnt hydrolocked yet and didnt notice any water in the oil
    im sure theres some in the cylinder judging by the way it was misfiring
    gonna tear it down tomorrow.so ill know for sure then..
    If everything checks out and its just a gasket ima runs some cheap oil for about 50-100 miles and change it again just to make sure if there was any possible water.gonna send the heads in to have checked out and resurfaced also. Any tricks to pulling the lim off if its full of coolant?
  5. #5 Re: Motor Done!!!
    St. Louis
    Yea, disonnect the lower rad hose and let it rip. You have to drain the system anyway to remove the LIM as you have to remove the tensioner assembly to get the coolant elbow out of the LIM and block. There should be minimal coolant left in the LIM at that point.
    If you find you really have to pull the LIM and the heads then just be sure you wash the valley/lifters out with some cheap oil and drain it all before refilling. This will ensure you get as much coolant out of where its not supposed to be thus hopefully saving your bearings
    Also, when reassembling everything be sure to get new head bolts as I believe they are TTY and need to be replaced. Also grab yourself a torque wrench that can do degrees, as this is required in the tightening of these bolts. And of course don't forget to put sealant around the LIM bolts that go into the water jackets as it will wick up the threads eventually, and RTV in all 4 corners where the LIM, block, and heads meet.
  6. #6 Re: Motor Done!!!
    Dec 2010
    Modesto
    So i got the car torn down pulled the heads off and didnt notice any
    weak spots in the head gaskets...did notice when i pilled the uim
    off i had lots off coolant and oil settled in the top of the lim....
    now do mind you i have an hv3 insert thinking maybe the coolant passages
    that go into the uim from the lim may have been letting coolant threw????
  7. #7 Re: Motor Done!!!
    Jersey
    oil mixed with coolant in the lim valley?
    do u have aluminum or plastic gaskets?
    16' wrx sti- stock
  8. #8 Re: Motor Done!!!
    Dec 2010
    Modesto
    Oil water mix in the top of the lim..didnt notice any inside the lim
    and there all plastic gaskets uim lim did notice the gaskets were in horrible shape.
    the plastic gasket on the lim to the h ead it had started pulling itself apart from the rubber seals when i get home ill take a pic of it....sure my discription isnt the greatest..
    oh and i also had very bad bloackage in the coolant port of the rear head...sure that played part in the heating issues...im sending them to my buddies shop tomorrow and
    having them checked out
  1. 700 HP motor
    By Nickell in forum Visual/Body Modifications
    Last Post: 10-13-2010, 09:26 AM
  2. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
  3. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
  4. sad day for me my motor went. what do i do ?
    By 98gtp1000 in forum General Tech Discussion
    Last Post: 02-07-2009, 07:47 PM
