Thread: Poor man HV3
Results 1 to 20 of 22
  1. #1 Poor man HV3
    Austin
    I want to get a HV3 but have no money. Has anyone tried running the enigne with the runner insert?
  2. #2 Re: Poor man HV3
    you mean without?
    Because you could just cut it.
    Make it shorter but leave mabye 1" and the sidewalls of the insert intact so its still somewhat structurally sound.
  3. #3 Re: Poor man HV3
    GT Level Member Wrongwayislost77's Avatar
    Arvada, Colorado
    You should get one of those spiffy metal intake manifolds with the idler pulley like this:
    Sig2
    30%, 5000k's, GMPP/Addco Sways, BMR Braces/Arms, FE3 Struts, WBS Springs, 12" w/ SS Lines & F-Bodies. Wiz, HVTB, HV3, CPlog, Shift Kit, ZZP 1.0, Alt/Volt Boost, Etc.
  4. #4 Re: Poor man HV3
    Austin
    I want one but I dont have that kind of money.
  5. #5 Re: Poor man HV3
    Austin
    the cut it but remove it all together.
  6. #6 Re: Poor man HV3
    Portland Oregon
    You need a little runner length. How about shaving down your stock runner insert?
  7. #7 Re: Poor man HV3
    Arvada, Colorado
    I have an HV3, I would suggest shaving down the stocker; it was not worth the $150 I paid for it used. A Dremel is going to save you a Lot of money if you own a 3800.
    Sig2
  8. #8 Re: Poor man HV3
    Omaha, NE
    My HV3 looked completely different than my stock runners in every way...
    I personally will not recommend that you trim yours because who knows what could happen.
    Wait until you find one used if you can't afford new, but in all honesty, if you can't afford the mods, you shouldn't be modding your car anyway.
  9. #9 Re: Poor man HV3
    Arvada, Colorado
    ^^^True that if you can't afford mods, you shouldn't mod it. I would suggest saving/planning and scoping for deals.
    Sig2
  10. #10 Re: Poor man HV3
    St. Louis
    Or just buy this one...
    http://www.grandprixforums.net/fs-or...zzp-42823.html
    From what I've read/heard the HV insert is only good in the upper (3500+) RPM band. How long during daily driving does your car live at or above these rpms?
    Personally I'd save the money and put it towards other things. If I want to go faster I'll top swap and call it a day.
  11. #11 Re: Poor man HV3
    Quote Originally Posted by Wrongwayislost77 View Post
    Quote Originally Posted by white2002gt View Post
    Understand
    That doesnt make any sense, why cut it if you're removing it.
    Quote Originally Posted by OH4CompG View Post
    This is what i suggest
    sweeeeeeeeet
    Lol. Thats because they did it the smarter way.
    But its so much more expensive just to get rid of a small restriction.
    Unless they literally warp, then they're good for the modding.
    Quote Originally Posted by FordMan77 View Post
    These engines dont need any power below 3500, the manifolds ensure we have more than enough torque down there.
    Top swaps start at one grand and you'd be wasting your time if you didn't jump straight for heads and cam since its all apart. That puts it at 2 plus.
    Now you're into turbo range.
    They're also much less engine invasive.
  12. #12 Re: Poor man HV3
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    dang, was it really necessary to quote every post in this thread?? espeically the pointless one word answer ones...
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  13. #13 Re: Poor man HV3
    Jul 2008
    Tampa, FL
    lol, thanks for the sales pitch...hahahaha
  14. #14 Re: Poor man HV3
    Arvada, Colorado
    You do know I was joking, yes?
    Sig2
  15. #15 Re: Poor man HV3
    Jul 2008
    Tampa, FL
    haha, i got it...
  16. #16 Re: Poor man HV3
    Feb 2008
    Just keep an eye out for the newest gen HV3, they can be had for around $100. I think I got mine for 120 brand new from another user. I wouldn't suggest cutting the stock runners.
  17. #17 Re: Poor man HV3
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by Mjcanton View Post
    I agree. I picked mine up used as well.
  18. #18 Re: Poor man HV3
    does 100 include a new gasket?
  19. #19 Re: Poor man HV3
    Feb 2008
    You really shouldn't need a new gasket. Just clean up the old one. They are plastic and rubber, so unless yours is trashed for some reason it'll be fine.
  20. #20 Re: Poor man HV3
    Thats just why you replace them.
    They crush over time.
  1. my poor LIM
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2011, 11:48 AM
  2. Poor car...
    By iceman977th in forum Off Topic Discussion
    Last Post: 12-21-2010, 12:20 PM
  3. poor gas mileage
    By 05grandprixgt in forum General Tech Discussion
    Last Post: 02-14-2010, 07:32 AM
  4. Poor mpg! Help
    By rocafella2032 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-11-2009, 08:15 PM
  5. poor GTP
    By hotshot in forum The Rant Forum
    Last Post: 10-01-2008, 08:08 AM
