Thread: what next?
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 89
  1. #1 Re: what next?
    Nitrous...plz don't say nos.
    *sigh*
    LOL
  2. #2 Re: what next?
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    Nozzzzz
  3. #3 Re: what next?
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    id probally spell it wrong
  4. #4 Re: what next?
    NOS...is for ricers.
    And if your doing heads...ER Rockers with ported heads will work but then you'd NEED headers to maximize that effort.
    So, back to my other post...BUY HEADERS.
    And off a bottle...with cam and headers...I'd say low 14's. 13's are pretty rare IMO on a stock trans.
  5. #5 Re: what next?
    Dec 2010
    Ohio
    I think I might just save my money cause heads and rockers plus trans work would be like 2 grand
  6. #6 Re: what next?
    SE Level Member black.gtp's Avatar
    Apr 2008
    Indiana
    Quote Originally Posted by Taz Magester View Post
    just buy my car lol
    PRJ Built enough said!!!!
    www.prjperformance.com
  7. #7 Re: what next?
  8. #8 Re: what next?
    Dec 2010
    Ohio
    good choice. drugs and hookers are more fun anyway.
    that was my plan
  9. #9 Re: what next?
    Dec 2010
    Ohio
    I doubt i could afford it and does your trans even work yet?
  10. #10 Re: what next?
    Apr 2008
    Indiana
    all the parts are on the way its getting a new chain, a 4340 zzp input shaft
  11. #11 Re: what next?
    above .515 lift you need SOMETHING to increase valve guide clearance.
  12. #12 Re: what next?
    I would never run a high compression motor and boost without optimal flow mods...running high compression without headers is like tossing a 3.4" on a stock L67...is it doable? Sure. Is it safe? Probably not.
  13. #13 Re: what next?
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Maybe shave the heads to raise compression?
    In addition to port & polish.
  14. #14 Re: what next?
    Kansas
    I top swapped my car for less then a grand.
    But then spent well over a grand on headers, tune, gauges, port work, and paint.
    Top swapping a car for less then a grand is easy but getting everything else to properly run and watch your top swap is what will cost you.
    SOLD 1999 GT Silvermist TS
  15. #15 Re: what next?
    Grand Island, Nebraska
    Gasket kit from Wbodystore -$300
    2 oil changes- $40
    Coolant $15
    Vac line $15
    Belts $30
    coolant elbows $5
    Valve Seals $20
    SC oil $10
    Spark Plugs $10
    rocker bolts $20
    Tune unless you plan on running with a canned one with the wbody gasket kit ~$100
    Injector connectors if you have an 01+ $40
    Headers - $175
    Most people will tell you to get the heads checked also before you but them on.
    Thats about $750 not counting head work and assuming you run into no problems. add that to your hard parts.
    I wouldnt consider a top swap complete without all that because you need them to drive the car pretty much.
    Im not saying you cant get all the hard parts for super cheap, its the rest that screws you.
  16. #16 Re: what next?
    You can get the rebuild gasket kit from your local auto parts store for around 150 bucks...that is one place that is screwing ya. Also...injector connectors? That's for '04+ EV injector cars.
    Also...if your coolant is good prior to the swap...not sure why'd you replace it. Also...DHP Tuning is free if you DIY it or you know someone that can get it done.
  17. #17 Re: what next?
    You need injector connectors for 01+ cars. My friend just did his and he needed them. But he didnt know because no one told him/ knew about it. i even tried connecting my L67 injectors to my L36 wiring harness. Doesnt work. And im gonna have to check the parts store to see if i can find something like that. the gasket kit may seem more expensive because it also comes with a canned tune also. And dont you have to pay to unlock the PCM? And i dont know anyone who would like to tune my car for free.
  18. #18 Re: what next?
    Dec 2010
    Ohio
    waaa
  19. #19 Re: what next?
    Sorry for the Threadjack OP^
  20. #20 Re: what next?
    Dec 2010
    Ohio
    so i got some stuff changed on my tune and what not..
