Thread: Overheating?
Results 1 to 6 of 6
  1. #1 Re: Overheating?
    Never Never Land
    my gtp used to get hot like that...replaced the tsat without much help..water pump helped some but it still gets hot when its nice out crusing under 30mph....i think my problem is my fans...they dont spin for chit
  2. #2 Re: Overheating?
    a coolant flush would not be a bad idea, if you have brown gunt on the cap then its prolly about time to swap out the dexcool and change to all makes all model coolant (green).
    also it could be that you have air in the cooling system causing the car to run hotter and messing with the sensor.
    bleed the air out and see if that help.
  1. overheating
    By mcdriver in forum General Tech Discussion
    Last Post: 01-24-2011, 01:24 PM
  2. **overheating**
    By tmackster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2010, 04:18 PM
  3. Overheating!!
    By Pogo D Klown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-23-2009, 03:48 PM
  4. overheating
    By famouspork in forum General Tech Discussion
    Last Post: 05-27-2009, 09:22 AM
  5. HELP!! overheating
    By sciontc1011 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:55 PM
