Thread: 97 GP GT, Car vibrates a little when idle.
Results 1 to 4 of 4
  1. #1 97 GP GT, Car vibrates a little when idle.
    Florida
    Sound goes away when I start driving. Sometimes I hear it on the left side, towards the front and sometimes I hear it on the passenger side. Sometimes its quiet. Any ideas? ALSO, I posted something about a cruise vacuum selonoid, its an error code I got. Does anyone know wth that means?
  2. #2 Re: 97 GP GT, Car vibrates a little when idle.
    St. Louis
    Probably bad/worn mounts. Check the trans and motor mounts. Also check the dogbones up front as they way be worn out as well.
    And if you have a code for the cruise vac. solenoid, then I would check all your vac. lines and then the solenoid itself. might just be shot.
  3. #3 Re: 97 GP GT, Car vibrates a little when idle.
    Troy, Michigan
    hey man...you live where there is snow? even snow underneath your car, can cause vibrations...just a thought
  4. #4 Re: 97 GP GT, Car vibrates a little when idle.
    Florida
    Eh...florida is probably not seeing much snow this time of year...XD.
    Probably worn out motor mounts.
    How many miles are on the car?
    Easy way to test, is to put the car in park, and pop the hood. Grab on to the engine, and pull it forward. If it moves easily back and forth, you need new motor mounts.
    Also, where in Florida do you live, if you dont mind.
  1. Car Vibrates Help
    By shiftshot in forum General Tech Discussion
    Last Post: 01-28-2011, 02:09 PM
  2. Replies: 8
    Last Post: 03-11-2010, 07:59 AM
  3. Dash Vibrates when AC/Heater is on High
    By corbancantread in forum General Tech Discussion
    Last Post: 02-02-2010, 10:33 AM
  4. gtp shakes/ vibrates
    By backinblackgtp in forum General Tech Discussion
    Last Post: 12-13-2009, 01:42 AM
  5. Car still vibrates....please help
    By bcrosby51 in forum General Tech Discussion
    Last Post: 03-30-2009, 04:40 PM
