Thread: question about rockers?
Results 1 to 20 of 29
  1. #1 Re: question about rockers?
    Jersey
    Quote Originally Posted by biggt View Post
    whats exactly a plug?
    Plog- ported front manifold (zzp makes them)
    The rollers are less valve train friction. If your going to run 1.9 rollers i would also pick up L76 valve springs to go with them. If your going to run 1.9 modded ones you can keep your stock springs but, you wont be able to raise shift points past 5800, due to valve float.
    16' wrx sti- stock
  2. #2 Re: question about rockers?
    Feb 2008
    Quote Originally Posted by 99prixgt View Post
    The Plog is not a ported front mani - it is a Power Log. It is a replacement for the front manifold that flows better than stock.
    To the OP: You are going to want the ER rockers for sure. They make more power on N/A cars. ZZP has a tech article on them as well if you are interested in reading it. You will also need a rocker install kit. You might as well replace the factory springs with LS6 springs too.
    Another mod I would recommend with that setup is ZZP's HV3. Good for some decent HP especially paired with rockers and headers.
    If you do those two things you should get some pretty decent gains.
    ER rockers tend to add 15-20HP
  3. #3 Re: question about rockers?
    Jersey
    Quote Originally Posted by Mjcanton View Post
    ? like i said zzp makes them brahh
    you can use L76 (g8 gt) valve springs, their a little cheaper, and a tad softer than ls6 springs, their good if your never going cammed. Ive used them on my rocker'd car for about 20,000 miles.
    16' wrx sti- stock
  4. #4 Re: question about rockers?
    Dec 2008
    Lawndale, CA
    You will like the ER rockers. I also recommend you get the HV3.
  5. #5 Re: question about rockers?
    Feb 2008
    You said they are ported front manis.. They are a complete redesign. Your post could have mislead him to think he needs ported manis, not a PLOG, since you said they were the same thing brahhh.
  6. #6 Re: question about rockers?
    Jersey
    16' wrx sti- stock
  1. rockers/springs/shift points question
    By quinnp12 in forum General Tech Discussion
    Last Post: 08-28-2009, 11:16 PM
  2. ZZP ER Rockers
    By GP2003GT in forum Off Topic Discussion
    Last Post: 06-11-2008, 08:43 PM
