Thread: question about rockers?
Results 1 to 20 of 29
  1. #1 question about rockers?
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    hey guys, i have been looking and reading about rocker's (dont tell me to install a cam).
    my questions are witch one is the best for my car.
    N/A with headers down pipe, and intake.
    i found those
    ZZ Performance
    ZZ Performance
    what other parts should i also buy?
    will i feel a little difference?
    how hp will should i be expecting?
    to be more on the safe side what other mods should i do at the same time?
    thanks
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  2. #2 Re: question about rockers?
    Charles City, IA
    I guess the er rockers are better for a n/a car, never delt with them tho. If you are staying n/a get a hv3 and a plog and dp or headers. then a tune.
    SMGPFC Two Nipple General
  3. #3 Re: question about rockers?
    Jul 2010
    Montreal
    whats exactly a plug?
  4. #4 Re: question about rockers?
    Jersey
    Quote Originally Posted by biggt View Post
    Plog- ported front manifold (zzp makes them)
    The rollers are less valve train friction. If your going to run 1.9 rollers i would also pick up L76 valve springs to go with them. If your going to run 1.9 modded ones you can keep your stock springs but, you wont be able to raise shift points past 5800, due to valve float.
    16' wrx sti- stock
  5. #5 Re: question about rockers?
    Jul 2010
    Montreal
    ok lets say i get the 1.9 modded and keep the stock springs,
    what else would i need to run them.
    because i dont think i will have my car tuned to have it shift over 5800..
  6. #6 Re: question about rockers?
    Feb 2008
    Quote Originally Posted by 99prixgt View Post
    The Plog is not a ported front mani - it is a Power Log. It is a replacement for the front manifold that flows better than stock.
    To the OP: You are going to want the ER rockers for sure. They make more power on N/A cars. ZZP has a tech article on them as well if you are interested in reading it. You will also need a rocker install kit. You might as well replace the factory springs with LS6 springs too.
    Another mod I would recommend with that setup is ZZP's HV3. Good for some decent HP especially paired with rockers and headers.
    If you do those two things you should get some pretty decent gains.
    ER rockers tend to add 15-20HP
  7. #7 Re: question about rockers?
    Jul 2010
    Montreal
    thanks for the help,
    I heard instead of buy ZZP's HV3 you can just remove the runners and that will do the same thing??..
    has any one heard of that?
  8. #8 Re: question about rockers?
  9. #9 Re: question about rockers?
    That'll probably hurt your more than anything...that for sure isn't helping because the air isn't being directed anywhere
  10. #10 Re: question about rockers?
    Jul 2010
    Montreal
    ight cool, thanks guys
  11. #11 Re: question about rockers?
    Feb 2008
    Werd.
  12. #12 Re: question about rockers?
    I've seen a couple guys cut the runners down to accomplish the same. The posted good results, but it's unknown if that is as good as HV3 or maybe better.
  13. #13 Re: question about rockers?
    Jersey
    Quote Originally Posted by Mjcanton View Post
    ? like i said zzp makes them brahh
    you can use L76 (g8 gt) valve springs, their a little cheaper, and a tad softer than ls6 springs, their good if your never going cammed. Ive used them on my rocker'd car for about 20,000 miles.
    16' wrx sti- stock
  14. #14 Re: question about rockers?
    Dec 2008
    Lawndale, CA
    You will like the ER rockers. I also recommend you get the HV3.
  15. #15 Re: question about rockers?
    Jul 2010
    Montreal
    that would be my next step after i lower the car ( if everything works out like a i want it will be done by mid April begining of may)
  16. #16 Re: question about rockers?
    Feb 2008
    You said they are ported front manis.. They are a complete redesign. Your post could have mislead him to think he needs ported manis, not a PLOG, since you said they were the same thing brahhh.
  17. #17 Re: question about rockers?
    Jersey
    16' wrx sti- stock
  18. #18 Re: question about rockers?
    Feb 2008
    Proving your idiocy..
  19. #19 Re: question about rockers?
    Jersey
    LOL ok dude. I don't pick internet fights, swing your e-dick somewhere else.
    16' wrx sti- stock
  20. #20 Re: question about rockers?
    Pennsylvania
    Mj had a pretty valid point.. just sayin
    Plog and ported manifolds are different things, that's all he meant...
    That can be really confusing for a guy who doesnt know
  1. rockers/springs/shift points question
    By quinnp12 in forum General Tech Discussion
    Last Post: 08-28-2009, 11:16 PM
  2. ZZP ER Rockers
    By GP2003GT in forum Off Topic Discussion
    Last Post: 06-11-2008, 08:43 PM
